(defun c:MapCom (/ ent Obj lEnt) (vl-load-com) (while (setq ent (car (nentsel "\nSelect Object: "))) (setq Obj (vlax-ename->vla-object ent) typ (cdr (assoc 0 (entget ent))) ) (cond ((vl-position typ '("CIRCLE" "ARC" "ELLIPSE" "SPLINE" "XLINE")) (comInv typ nil) (PropMatch Obj (entlast)) ) ((eq "LWPOLYLINE" typ) (comInv "pline" nil) (PropMatch Obj (entlast)) ) ((eq "LINE" typ) (setq lEnt (entlast)) (comInv typ nil) (foreach ent (EntCol (if lEnt lEnt (entlast))) (PropMatch Obj ent) ) ) ((eq "HATCH" typ) (setq lEnt (entlast)) (comInv typ t) (if (not (eq lEnt (entlast))) (PropMatch Obj (entlast)) ) ) ((eq "VIEWPORT" typ) (setq lEnt (entlast)) (comInv "-vports" nil) (if (not (eq lEnt (entlast))) (PropMatch Obj (entlast)) ) ) ) ) (princ))(defun PropMatch (bObj dObj) (or (eq 'VLA-OBJECT (type bObj)) (setq bObj (vlax-ename->vla-object bObj)) ) (or (eq 'VLA-OBJECT (type dObj)) (setq dObj (vlax-ename->vla-object dObj)) ) (foreach prop '(Layer Linetype LinetypeScale Color Lineweight ViewportOn ShadePlot DisplayLocked GradientAngle GradientCentered GradientColor1 GradientColor2 GradientName HatchObjectType HatchStyle ISOPenWidth Origin PatternAngle PatternDouble PatternScale PatternSpace ) (if (and (vlax-property-available-p bObj prop) (vlax-property-available-p dObj prop T) ) (vlax-put-property dObj prop (vlax-get-property bObj prop)) ) ))(defun EntCol (x / x) (if (setq x (entnext x)) (cons x (EntCol x)) ))(defun comInv (com flag) (if flag (initdia) ) (command (strcat "_." com)) (while (eq 1 (logand 1 (getvar "CMDACTIVE"))) (command pause) ))
