Author Topic: profile reverting to vanilla  (Read 1429 times)
ELOQUINTET
« on: March 15, 2006, 02:12:03 PM »
i had to install a copy of inventor and configure mdt 2006 for one of our engineers. it went ok but when i closed and reopened mdt it reverted back to vanilla profile not the one i created. my boss recalls this to be a bug and told me to find the vanilla.arg and overwrite it with mine but this doesn't work. can anyone help me out?
Lin-Z
Re: profile reverting to vanilla
« Reply #1 on: March 15, 2006, 02:53:50 PM »
If you use the icon shortcut to open the software, attach
 /p "<Profile name>"
to the end of the target path.
Greg B
  • Tell me a Joke!
« Reply #2 on: March 15, 2006, 02:57:03 PM »
You on a network?
Might be picking the profile up from somewhere else.
ELOQUINTET
« Reply #3 on: March 15, 2006, 03:34:40 PM »
i tried applying  a startup switch but it does nothing. they are on a seperate network from me and i'm not really sure how it's setup our it dept is insane. what i did which isn't really a permenant fix is i used a lisp that saves and loads support paths. so i saved them from mine then i switched to the vanilla and loaded then exported the vanilla. they dont really use autocad that much and when they do it's minimal.
