Author Topic: need a quick piece of code ...  (Read 6622 times)
Re: need a quick piece of code ...
« Reply #15 on: April 27, 2010, 01:41:41 PM »
With that said, what are you Se7en, referring to when you mentioned:
And obviously the "proper use of a subject line" process as well (no one will ever have this problem and they certainly wont need to search for it in the future either).
I would believe Se7en is referring to the thread being called 'Need a Quick Piece of Code'.
The site's search utility obviously uses thread titles as a search parameter, and your title is hence very ambiguous for someone trying to find the information posted herein.
Lee
Hangman
« Reply #16 on: April 27, 2010, 02:24:10 PM »
Lee
Ahhh, ...  hadn't thought of that, but a good point.   Most of the time when I am searching, I'm finding points of interest IN the post, not the title itself.  Perhaps that is another reason I have trouble with my searches as well.
Hangman  8)
Drafting Board, Mechanical Arm, KOH-I-NOOR 0.7mm
alanjt
  • Standby for witty remark...
« Reply #17 on: April 27, 2010, 02:25:13 PM »
Glad you sorted things out. :)
Dropbox
« Reply #18 on: April 27, 2010, 10:57:15 PM »
oh don't mind me; I go on rants every now and again. ...but LeeMac said it very well if you ask me.
