Author Topic: Creating object under another..  (Read 2336 times)
Andrea
« on: September 01, 2009, 09:19:17 AM »
Hi all...
Anyone know how to create an object under another without using draworder or cdorder ?
(setq MyPLINE
(entmakex
  (list
    '(0 . "LWPOLYLINE")
    '(100 . "AcDbEntity")
    '(100 . "AcDbPolyline")
    '(90 . 6)
    '(70 . 1)
    '(43 . 0.0)
    '(38 . 0.0)
    '(39 . 0.0)
    (cons 10 p1)
    (cons 10 p2)
    (cons 10 p3)
    (cons 10 p4)
    (cons 10 p5)
(command "._draworder" MyPLINE "" "_A" MyObject "")
Keep smile...
Re: Creating object under another..
« Reply #1 on: September 01, 2009, 09:26:23 AM »
Maybe you could entmod the object you want on top?
Just a guess.
« Reply #2 on: September 01, 2009, 09:43:42 AM »
Perhaps use the relevant methods on the Sortents Table?
Example:
(defun getOrder  (/ doc spc Dic sort order)
  (setq doc (vla-get-ActiveDocument
              (vlax-get-Acad-Object))
        spc (if (zerop (vla-get-activespace doc))
              (if (= (vla-get-mspace doc) :vlax-true)
                (vla-get-modelspace doc)
                (vla-get-paperspace doc))
              (vla-get-modelspace doc)))
  (if (vl-catch-all-error-p
        (setq sort
          (vl-catch-all-apply 'vla-item
            (list
              (setq Dic
                (vla-getextensiondictionary spc)) "ACAD_SORTENTS"))))
    (setq sort (vla-addobject Dic "ACAD_SORTENTS" "AcDbSortentsTable")))
  (vla-getfulldraworder sort 'order :vlax-false)
  (if (< 0 (vlax-safearray-get-u-bound order 1))
    (vlax-safearray->list order)))
Joe Burke
« Reply #3 on: September 01, 2009, 09:46:32 AM »
There are vlisp methods which can be used to control draworder. Example: see help regarding MoveToTop method.
Spike Wilbury
« Reply #4 on: September 01, 2009, 09:56:12 AM »
edit...
i remember in the old days, the use of the command copy and move and using as the base point the 0,0,0
« Last Edit: September 01, 2009, 10:07:33 AM by Esquivel »
Andrea
« Reply #5 on: September 01, 2009, 10:31:43 AM »
well...thanks all...
I've made many test for DiLEADER program...
and I can't understand why the result is working alternatively....
see the animated Gif..
I have tried with Wipeout,Solid and LWpolyline..but the result still the same..  :|
(I have put a blue color to let you see what it's happen..)
Keep smile...
Andrea
« Reply #6 on: September 01, 2009, 11:16:45 AM »
Fixed !
Thanks again all..
i'll upgrade the routine soon.. :wink:
Keep smile...
« Reply #7 on: September 01, 2009, 11:18:16 AM »
What was the solution Andrea?  Or are we going to have to wait for the update...  ;-)
Andrea
« Reply #8 on: September 01, 2009, 11:49:45 AM »
I've made a mistake creating object order vs Modified object.. :lmao:
but I take your sortents code as a snipet.
thanks.  ;-)
Keep smile...
« Reply #9 on: September 01, 2009, 11:51:33 AM »
I see - no worries :-)
Looking forward to the next DiLeader update  :-)
