Author Topic: Fuzzy Dots  (Read 5282 times)
ChrisCarlson
Fuzzy Dots
« on: April 01, 2014, 08:18:19 AM »
I can't figure out where these dots are coming from
Noticed them similar to this;
I regenerated the screen;
System Specs:
ACAD 2014
Xeon W3520
8GB Ram
NVidia K2000D Video Card
Krushert
  • FREE BEER Tomorrow!!
Re: Fuzzy Dots
« Reply #1 on: April 01, 2014, 09:33:44 AM »
Is that part of the Orion's Belt?  :-P
Maybe Points??  Anything show up on the properties pallette
Re: Fuzzy Dots
« Reply #2 on: April 01, 2014, 09:49:54 AM »
looks like some sort of linetype
your graphic isn't very clear, you just made me clean my monitor
what does your ribbon change to when you select it
alanjt
  • Standby for witty remark...
Re: Fuzzy Dots
« Reply #3 on: April 01, 2014, 09:58:47 AM »
LIST them.
Dropbox
ChrisCarlson
Re: Fuzzy Dots
« Reply #4 on: April 01, 2014, 10:20:50 AM »
Not an object, just a bunch of "dots" which get closer and more frequent in numbers the closer you zoom in.
Also receiving FATAL ERROR's now  :realmad:
alanjt
Re: Fuzzy Dots
« Reply #5 on: April 01, 2014, 10:23:51 AM »
Doesn't look like blipmode markers.
purge all
purge regapps
audit
Dropbox
Re: Fuzzy Dots
« Reply #6 on: April 01, 2014, 11:21:37 AM »
one cool April Fools prank
suggest wblock out only what you can select and abandon that file
ChrisCarlson
Re: Fuzzy Dots
« Reply #7 on: April 01, 2014, 02:45:38 PM »
When I attempt to select them
Notta...
  :realmad:  go away dots
Re: Fuzzy Dots
« Reply #8 on: April 01, 2014, 03:36:21 PM »
send me copy of that file swampname@earthlink DOT net
Re: Fuzzy Dots
« Reply #9 on: April 01, 2014, 03:48:22 PM »
See if this fixes it (vlr-remove-all).
snownut2
  • Bricscad 22 Ultimate
Re: Fuzzy Dots
« Reply #10 on: April 01, 2014, 05:01:37 PM »
My eye doc told me if I ever see that to call him immediately.....
Re: Fuzzy Dots
« Reply #11 on: April 01, 2014, 07:55:47 PM »
Could this be an April Fool's Joke?  >:D
Re: Fuzzy Dots
« Reply #12 on: April 01, 2014, 09:08:31 PM »
I thought so ... but wasn't sure if the OP was the perpetrator or the victim.
Re: Fuzzy Dots
« Reply #13 on: April 01, 2014, 09:27:03 PM »
Already called it
Re: Fuzzy Dots
« Reply #14 on: April 01, 2014, 11:10:46 PM »
Michael,
I was referring to the post not the drawing.
Without a DWG to prove they really exist who can say.  8)
