The titlesuppressed property will change the Title row to a Header row or Data row (depending on whether the headersuppressed property is set) and the row will then inherit the corresponding properties as configured in the Table Style assigned to the table for that row type; changing the value of this property will not unmerge the cells, as merging cells is not a property of the row type.
