Author Topic: Unpurged drawing....  (Read 5185 times)
Andrea
« on: January 06, 2016, 02:20:23 PM »
Hi everyone..
the drawing attached have 8MB....but no entity..
I'm trying to find out what is the cause..
anyone can take a look and tell me what's the problem ?
Thank you.
Keep smile...
Re: Unpurged drawing....
« Reply #1 on: January 06, 2016, 02:34:25 PM »
Drawing contains 3680 anonymous block definitions and 136575 entries in the ACAD_DGNLINESTYLECOMP dictionary.
Try the following:
  1. (defun c:purgeall nil
  2.     (dictremove (namedobjdict) "acad_dgnlinestylecomp")
  3.     (command "_.-purge" "_r" "*" "_n")
  4.     (repeat 3 (command "_.-purge" "_a" "*" "_n"))
  5.     (princ)
  6. )
« Last Edit: January 06, 2016, 02:37:44 PM by Lee Mac »
« Reply #2 on: January 06, 2016, 02:41:19 PM »
Here's a tool as well.
« Reply #3 on: January 06, 2016, 02:48:20 PM »
That's exactly what I used to diagnose the drawing - a great utility from MP.
Squirltech
« Reply #4 on: January 06, 2016, 02:55:37 PM »
That's pretty sweet! Thanks for sharing.  8-)
"The only thing left to do is everything" - Jesse James
« Reply #5 on: January 06, 2016, 02:57:04 PM »
Yup .. I've been using it for years :). It's amazing how littered drawings are nowadays.
Squirltech
« Reply #6 on: January 06, 2016, 03:03:04 PM »
We do quite a large amount of plat production here and the drawing with the least amount of objects will have the largest file size ever! It's all from doing a "save as" on a drawing that was done a year ago and just reusing it over and over and over...  :rolleyes2:
Some of our production techs don't even know how to start with a TEMPLATE or how to create a NEW drawing.  :grumpy:
Most of this has been corrected by now but once in a while we'll come across one of those "old balloon" drawings.
El Bachaco
« Reply #7 on: January 07, 2016, 01:45:16 PM »
Saludos Amigos ..... months ago I got a problem with me a file with very little information but large ..... I was suffering for several days until I got the solution ...... Got Somewhere following hotfix and hallelujah .... problem solved .....
the file is reduced test4.dwg to 74k ......
Command: NETLOAD
Command: DGNPURGE
Purged 1463 unreferenced complex linetype records (of 1463).
Purged 136575 unreferenced strokes (of 136575).
Command:
Command:
Command: _qsave Updating Indexes for block *Model_Space
Done.
Done.
the address is https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-C2-AE-dgn-hotfix.html?v=2013
excuse the English .... bye
Andrea
« Reply #8 on: January 07, 2016, 02:31:20 PM »
Thank you Guys..
Hi Lee,..
Question...how did you find that it was the "acad_dgnlinestylecomp" dict ?
Keep smile...
« Reply #9 on: January 07, 2016, 02:48:53 PM »
Thank you Guys..
Hi Lee,..
http://www.theswamp.org/index.php?topic=50734.msg558684#msg558684
Andrea
« Reply #10 on: January 07, 2016, 03:17:25 PM »
Thank you Guys..
Hi Lee,..
Sorry,..my poor English...
I mean,...without this great tool....where do you start for looking at ?
after purge and audit,..what must be the next step to look ?
the fact is that each problem have a solution...but I resolve most of them by a combinaison of "logic" and "deduction" and make test for each steps.
but when I can't found any more steps....how you guys doing to find out what the problem can be ?
search on the net,...ok,...but having the answer do not tell me why this issue is present and how can I found the right direction to look at..
it's like proxy's entities...who we never know wich kind of proxy's are..
maybe I'm not clear again...sorry for that..
thank you.
« Last Edit: January 07, 2016, 03:47:56 PM by Andrea »
Keep smile...
qwrtz
« Reply #11 on: January 07, 2016, 04:05:22 PM »
Doesn't the -exporttoautocad command get rid of all the proxies? Explodes them into simple Autocad entities, I thought.
Any time Autocad tells me there are proxies in a file I'm opening, I use that right away.
dgorsman
« Reply #12 on: January 07, 2016, 05:07:26 PM »
Thank you Guys..
Hi Lee,..
thank you.
Drawing size has to come from somewhere, and not everything is an entity (line, circle, etc.).  A lot of size comes down to data objects, which can be attached to entities or the drawing itself.  The latter is one of the first places I look, checking for various non-standard dictionaries (like AEC and AutoPLANT gunk).
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #13 on: January 07, 2016, 05:42:11 PM »
Thank you Guys..
Hi Lee,..
Aside from an obvious abundance of graphical entities, I would simply look for collections (including dictionaries) which contain large numbers of objects - of course, MP's 'Counts' program performs this analysis automatically for you, making it very easy to identify such bloated collections.
Patrick_35
« Reply #14 on: January 11, 2016, 10:38:38 AM »
