Author Topic: serialize collectionBase  (Read 6633 times)
Draftek
Re: serialize collectionBase
« Reply #15 on: November 28, 2007, 07:48:29 PM »
okay, you got me with that one. I can usually decipher the Australian but..... :)
« Reply #16 on: November 28, 2007, 07:49:56 PM »
yes, generics ..
thats what I meant by the reference to the last paragraph of the article I referenced to.
Glenn,
those samples look functionally familiar.
« Reply #17 on: November 28, 2007, 07:51:41 PM »
no flaming worries = nurries.
or
all is cool.
added:
it's actually just 'no worries'
Strine is easy if you hold your nose and run words together.
also added later:
* sometimes reality should not stand in the way of a good story
« Last Edit: November 28, 2007, 08:02:14 PM by Kerry Brown »
MaksimS
« Reply #18 on: November 29, 2007, 04:13:05 AM »
IMHO, everything's fine unless it's a keyed collection of elements. Here's an example:
1) There's an Attribute type, having Name property (String). Two Attributes are considered equal if their Names are equal.
2) There's also a generic keyed collection of Attribute elements named Attributes:
<Serializable()> _
Public Class Attributes
    Inherits KeyedCollection(Of String, Attribute)
    Sub New()
        MyBase.New()
    Protected Overrides Function GetKeyForItem(ByVal item As Attribute) As String
        Return item.Name
    End Function
Then, here's how you access collection elements (by name):
Dim myAttributes As New Attributes()
... fill the collection ...
Dim myAttribute As Attribute = myAttributes("KeyName")
Both Attribute and Attributes types need to be decorated with Serializable() attribute. That's it. You don't need to bother with property/method serialization attributes since only Public ones will get serialized/deserialized.
Regards,
Maksim Sestic
Glenn R
« Reply #19 on: November 29, 2007, 04:41:07 AM »
Glenn,
Hehe...I thought you would spot that Kerry.
Glenn R
« Reply #20 on: November 29, 2007, 04:42:39 AM »
also added later:
Correct on both counts there Kerry and yes you definately shouldn't let reality ruin a good yarn.
