Author Topic: [2013] Civil 3D project phases  (Read 3053 times)
Matt__W
  • I like my water diluted.
« on: February 04, 2013, 01:12:55 PM »
What's the recommened workflow for dealing with project phases?  Should you link in the various pipe networks and set them to an "existing pipe" style then model the new pipes?  And how would you handle demolition of a pipe segment?  With another pipe style?
Autodesk Expert Elite
BlackBox
Re: [2013] Civil 3D project phases
« Reply #1 on: February 04, 2013, 04:54:10 PM »
First, I would incorporate the project phase into your naming convention for the Pipe Networks.
If you are able to use the proposed pipes from one phase in another phase as existing, then do so as you've described.
If, however, you need to modify a copy of said prior phase pipe network(s), then consider exporting to LandXML, and importing into a separate Civil 3D Project, making the necessary revisions in the applicable phase of work.
My $0.02
bchapman
« Reply #2 on: February 04, 2013, 08:43:49 PM »
I'm assuming you are talking about working on multiple phases at one time, rather than completing one phase than moving onto another?  I'm also interested.
Matt__W
« Reply #3 on: February 04, 2013, 09:29:13 PM »
Yes, the first one - multiple phases at one time.
« Reply #4 on: February 05, 2013, 12:20:33 AM »
name the pipe networks...keep data in seperate phase specific files and use data shortcuts, and styles
Matt__W
« Reply #5 on: February 05, 2013, 10:23:40 AM »
That's what I figured.  Thanks!
