Author Topic: Autocad Jig Sampler Function C#  (Read 3226 times)
dawido000
« on: July 22, 2014, 02:47:14 PM »
Is there any way to get from user both Point3d or String value in EntityJig object? I would like to reach such effect as in attachment?
I tried something like here:
protected override SamplerStatus Sampler(JigPrompts prompts)
                        JigPromptStringOptions prOptions3 = new JigPromptStringOptions();
                        JigPromptPointOptions prOptions2 = new JigPromptPointOptions("\n");
                        prOptions2.Keywords.Add("Koniec");
                        prOptions2.Keywords.Add("Zamień");
                        prOptions2.Keywords.Default = "Zamień";
                        prOptions2.BasePoint = mPunkt1Biezacy;
                        prOptions2.UseBasePoint = true;
                        prOptions2.UserInputControls =
                            UserInputControls.Accept3dCoordinates |
                            UserInputControls.AcceptOtherInputString |
                            UserInputControls.GovernedByOrthoMode |
                            UserInputControls.GovernedByUCSDetect |
                            UserInputControls.UseBasePointElevation |
                            UserInputControls.AnyBlankTerminatesInput |
                            UserInputControls.InitialBlankTerminatesInput |
                            UserInputControls.NullResponseAccepted;
                        prOptions3.UserInputControls =
                        PromptResult prResult3 = prompts.AcquireString(prOptions3);
                        PromptPointResult prResult2 = prompts.AcquirePoint(prOptions2);
                        if (prResult3.Status == PromptStatus.OK)
                            strTekst = prResult3.StringResult;
                            return SamplerStatus.NoChange;
                        //if (prResult2.Status == PromptStatus.Cancel) return SamplerStatus.Cancel;
                        if (prResult2.Status == PromptStatus.Keyword)
                            //Jeżeli naciśnięto Zamień
                            if (prResult2.StringResult == "Zamień")
                                if (mPunktChwilowy == mPunkt1Biezacy)
                                    mStartPoint = mPunkt2Biezacy;
                                    mPunktChwilowy = mPunkt2Biezacy;
                                else
                                    mStartPoint = mPunkt1Biezacy;
                                    mPunktChwilowy = mPunkt1Biezacy;
                            return SamplerStatus.OK;
                        if (prResult2.Status == PromptStatus.None)
                        if (prResult2.Status == PromptStatus.Other)
                        else
                            mEndPoint = prResult2.Value;
Re: Autocad Jig Sampler Function C#
« Reply #1 on: July 22, 2014, 03:27:42 PM »
If you aren't happy with the answers here :-
http://forums.autodesk.com/t5/NET/bd-p/152
then you will need to be more explicit with your question.
dawido000
« Reply #2 on: July 23, 2014, 01:58:55 AM »
Sorry for my English. I am from Poland :). I try to get from User point3d (as in attachment), but I want to be possibility to get string also. I succeeded, but during entering the string, Editor Input is falshing every inputed letter. I used two functions at the same time.
prompts.AcquireString();
prompts.AcquirePoint();
I admit that I experiment now, because I have no ideas anymore.
