This is a subject that I am highly interested in Mr. Custard. I have plans to create overrules for certain duct fittings that will override the geometry because the content builder is incapable of drawing it correctly. That being said, I know that it is possible because I have seen a program that does it. They are able to override the geometry of duct fittings to display what they want. In addition, they are adding text to the fitting itself to display properties of the fitting. So, again it is possible. In answer to your question though, have you taken the display configuration into account? Is it possible that the current display configuration is overriding what your overrule?.
