Code Red => AutoLISP (Vanilla / Visual) => Topic started by: frostmourn on September 30, 2015, 11:28:08 AM
Title: Error after making field, referred to the Xref
Post by: frostmourn on September 30, 2015, 11:28:08 AM
Hello all. I have got a problem during working with external references. Here the file AC-11 was used in the file AC-22 as attached Xref. Then doing the following code in it:
As a result we are obtaining a list of field codes, refering to the text entities on a specified layer in the Xref. And now if we paste codes to the texts in AC-22 trying to make working field, then after saving drawing will constantly get an error window - "recommended to do RECOVER procedure" (don't remember right wording). I have tried to paste only textstrings; to process a simple block instead of Xref - all is good. Also tried using of Acad2016, saving in old versions, no matter. After re-opening file works correctly, audit shows 0 errors. Fields are the necessary condition here. :-( Can anybody give a solution or explanation at least? Will be happy even could to set off an error window. System - Autocad 2010 x64 sp3 rus, SPDSGraphics 8.0, windows 7 pro x64 sp1. Thanks in advance. Sorry for probably mistakes.
Title: Re: Error after making field, referred to the Xref
Post by: ronjonp on September 30, 2015, 11:43:13 AM
Not related to your code but ... first thing I see you should not be doing is putting special characters in your file names.
This is the dl'd file I see .. something weird going on.
Post by: frostmourn on October 01, 2015, 04:24:14 AM
Hmm, very strange... I see ordinary letters. It's something related with cyrillic encoding, I think. Ok, here are files with only numbers using (by the way, it had no effect according to my problem...).
