Code Red => AutoLISP (Vanilla / Visual) => Topic started by: TimSpangler on January 18, 2010, 11:11:10 AM
Can someone that is running 2004 tell me if this works:
(setq ActiveDoc (vla-get-activedocument (vlax-get-acad-object)))
(setq ActiveLayout (vla-get-ActiveLayout ActiveDoc))
(setq PlotStyleTables
(vlax-safearray->list
(vlax-variant-value
(vla-getplotstyletablenames
ActiveLayout
Any help would be appreciated.
Tim, do I need do anything more than paste this CODE to the command line for you?
No. That should be enough.
My guess is that it will return an error.
You guess correctly sir,
Now how much do I weigh?
Command: (setq ActiveDoc (vla-get-activedocument (vlax-get-acad-object)))
; error: no function definition: VLAX-GET-ACAD-OBJECT
Command: (setq ActiveLayout (vla-get-ActiveLayout ActiveDoc))
; error: no function definition: VLA-GET-ACTIVELAYOUT
Command: (setq PlotStyleTables
(_> (vlax-safearray->list
((_> (vlax-variant-value
(((_> (vla-getplotstyletablenames
((((_> ActiveLayout
((((_> )
(((_> )
((_> )
(_> )
; error: no function definition: VLA-GETPLOTSTYLETABLENAMES
copy/paste this line before, and run again.
Command: (vl-load-com)
((((_> ActiveLayout
((((_> )
(((_> )
((_> )
(_> )
That's odd.
That's odd.
Yea. I had '04 for awhile, and I coded with ActiveX, so I know those few calls will work, but the latter part was what I wasn't sure of.
I don't think that this works:
ActiveLayout
But I would have thought that everything else would.....?
CAB, do you still have 04?
This is what I get in 2004:
("acad.ctb" "DWF Virtual Pens.ctb" "Fill Patterns.ctb" "Grayscale.ctb" "monochrome.ctb" "Screening 100%.ctb" "Screening 25%.ctb" "Screening 50%.ctb" "Screening 75%.ctb")
(vlax-variant-value
ActiveLayout
(vlax-variant-value
ActiveLayout
That's what I hope to see. Do you have any service packs installed?
No service packs
If I am getting this error:
; error: ActiveX Server returned an error: Invalid index
That would tell me that it has something to do with the array??
Actually I get this as a return running your code from 'vlide' :
#<VLA-OBJECT IAcadDocument 0116b820>
#<VLA-OBJECT IAcadLayout 02dbcf64>
i got no errors. still using map 2004.
#<VLA-OBJECT IAcadDocument 01254f90>
#<VLA-OBJECT IAcadLayout 04b66ee4>
((((_> ActiveLayout
((((_> )
(((_> )
((_> )
(_> )
("acad.ctb" "C-PLAN.ctb" "CANON.ctb" "COLOOR.ctb" "DBKL.ctb" "DRAFT-BLACK.ctb"
"DRAFT.ctb" "DRAFT2.ctb" "DWF Virtual Pens.ctb" "Fill Patterns.ctb"
"Grayscale.ctb" "monochrome.ctb" "MPKJ.ctb" "QT.ctb" "Screening 100%.ctb"
"Screening 25%.ctb" "Screening 50%.ctb" "Screening 75%.ctb" "STRATAPLAN.ctb"
"WENDY.ctb")
