Author Topic: Kill Ashave again  (Read 1866 times)
One Shot
Kill Ashave again
« on: April 22, 2005, 06:11:44 PM »
When I load this lisp and I get this "Unknown Command".  I have checked the path and it is correct.  Can someone enlighten me on how to make it work?
(defun C:KILLASHADE()
   (command "-layer" "U" "ASHADE" "")
   (command "_.erase" (ssget "x" '((8 . "ASHADE"))) "")
   (command "_.purge" "B" "AVE*" "N")
   (command "_.purge" "LA" "ASHADE" "N")
Thank you,
Brad
Kill Ashave again
« Reply #1 on: April 22, 2005, 07:16:41 PM »
works for me ..
when do you get the message ?
load it again and try to run it, then post your commandLine output.
One Shot
Kill Ashave again
« Reply #2 on: April 22, 2005, 07:18:49 PM »
I got it to work.  The first time I must have loaded the wrong lisp.  But it works.
thank you,
