Code Red => AutoLISP (Vanilla / Visual) => Topic started by: One Shot on April 22, 2005, 06:11:44 PM
When I load this lisp and I get this "Unknown Command". I have checked the path and it is correct. Can someone enlighten me on how to make it work?
(defun C:KILLASHADE()
(command "-layer" "U" "ASHADE" "")
(command "_.erase" (ssget "x" '((8 . "ASHADE"))) "")
(command "_.purge" "B" "AVE*" "N")
(command "_.purge" "LA" "ASHADE" "N")
Thank you,
Brad
works for me ..
when do you get the message ?
load it again and try to run it, then post your commandLine output.
I got it to work. The first time I must have loaded the wrong lisp. But it works.
thank you,
