I have a group of layers where there are two layers for each object type...
S-BF is the record issue layer with color bylayer
S-BF-N is the new construction layer, whose color is RED.
So block "X" will always land on the same layer and always first land on the S-BF-N layer. When construction is complete it will move to the layer of the same name without the "-N" suffix.
I was hoping to simply use the cold below to grab all red layers ending in "*N" and push them back to record issue. Clearly that's not going to work.
Clearly I could just ssget for each new red construction layer individually and then move it to it's record issue layer.
(defun c:test44
( / col2 col3
Seems to me if the name is only different in that one has the "-N", I should be able to move all RED objects with the "-N" to the layer of the same name without the "-N".
