Author Topic: Scalelistedit - command  (Read 3596 times)
SPDCad
« on: March 29, 2007, 04:44:12 PM »
In what version of AutoCAD did the "scalelistedit" command come into play?
I am writing a lisp for someone and would like to use the command to store/edit scales in my programme.
Also how does autocad keep track of the scales in the list (text file, library, Xdata)?
Any help would be appreciated...
SPD
AutoCAD 2010, w/ OpenDCL
visit: http://reachme.at/spd_designs
Guest
Re: Scalelistedit - command
« Reply #1 on: March 29, 2007, 05:02:11 PM »
I believe '07 but am not 100% sure.   We skipped '06 and went from '05 to '07.  I see in your profile info you have 2006.  Does 2006 have it?  I know for a FACT that '05 did NOT have it.
« Reply #2 on: March 29, 2007, 05:05:15 PM »
Works in '06
Guest
« Reply #3 on: March 30, 2007, 08:23:27 AM »
Works in '06
Well, there's your answer!
Crank
« Reply #4 on: March 30, 2007, 02:19:58 PM »
In acad2006/2007 the scale list is stored in the registry. From acad2008 the scale list is part of your drawing.
This is a lisp from the Spago forum by Daniel Altamura:
(defun GETSCALELIST (/ MASSOC ScaleList ScaleListDict ScaleListEnts ScaleListNumber ScaleListUnits N DIGIT ACAD-KEY)
(defun MASSOC (KEY ALIST / X NLIST)
(foreach X ALIST
(if (eq KEY (car X))
(setq NLIST (cons (cdr X) NLIST))
(reverse NLIST)
(if (>= (atof (substr (getvar "acadver") 1 4)) 17.1)
(progn ; 2008+
(setq ScaleListDict (dictsearch (namedobjdict) "ACAD_SCALELIST")
ScaleListEnts (MASSOC 350 ScaleListDict)
ScaleList (list "")
            N 0
(repeat (length ScaleListEnts)
(setq ScaleList (cons (cdr (assoc 300 (entget (nth N ScaleListEnts)))) ScaleList)
N (1+ N)
(setq ScaleList (cdr (reverse ScaleList)))
(progn ; 2007-
(setq ACAD-KEY (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Scale List"))
(if (vl-registry-descendents ACAD-KEY T)(progn
(setq ScaleListNumber (/ (vl-list-length (vl-registry-descendents ACAD-KEY T)) 3)
ScaleList (list "")
N 0
(repeat ScaleListNumber
(if (>= N 10)
(setq DIGIT (itoa N))
(setq DIGIT (strcat " " (itoa N)))
(setq ScaleList (cons (vl-registry-read ACAD-KEY (strcat DIGIT ".ScaleName")) ScaleList)
N (1+ N)
(if (= (vlax-product-key) "Software\\Autodesk\\AutoCAD\\R17.0\\ACAD-5004:409")
(progn ; ADT 2007 ONLY
(foreach ScaleListUnits (list "Feet" "Inches" "Metric")
(setq ACAD-KEY (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\AEC\\5.0\\AecBase50\\Scales\\" ScaleListUnits))
ScaleList (list "")
N 0
(if (>= N 10)
(setq DIGIT (strcat "0" (itoa N)))
N (1+ N)
((= ScaleListUnits "Feet") (setq ScaleListFeet (cdr (reverse ScaleList))))
((= ScaleListUnits "Inches") (setq ScaleListInches (cdr (reverse ScaleList))))
((= ScaleListUnits "Metric") (setq ScaleListMetric (cdr (reverse ScaleList))))
(setq ScaleList (append ScaleListFeet ScaleListInches ScaleListMetric))
ScaleList
SPDCad
« Reply #5 on: March 30, 2007, 03:02:11 PM »
I see in your profile info you have 2006. I know for a FACT that '05 did NOT have it.
I was wondering if 2005 had the command, oh well i guess i will have to write something similar. My client only has 2005.
I guess I need to update my profile, I am 2008 user and thanks for the tip on 2008 scale edit list Crank!.
To everyone who helped, thanks much appreciated!  :mrgreen:
