Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Cuddles on December 21, 2014, 08:17:03 PM
Title: Retaining User Input When Repeating A Command
Post by: Cuddles on December 21, 2014, 08:17:03 PM
Hello All,
I'm just curious as to how i may have a program store a users inputs for when repeating a command. Example: A user invokes a command and enters at the command line say length and width, and then draws and exits the command. Upon re-invoking the command, the previous inputs are retained and user draws the object again if they desire or these values may be overwritten with new values.
Could someone explain to me how this can be done, or provide links to such sources explaining this topic.
Thanks,
Cuddles
Title: Re: Retaining User Input When Repeating A Command
Post by: Kerry on December 22, 2014, 03:41:55 AM
I'll assume the 'command' is one that you are writing. Something to play with.
