Author Topic: Trim Fence  (Read 2139 times)
Biscuits
Trim Fence
« on: March 02, 2007, 10:09:25 AM »
Anyone got any ideas how to change this mini-routine so that the fence line is not limited to a specific number of pics?
I've been able to do this but only if I remove the "(COMMAND "OSMODE" "47")"
(defun c:TRIMFNC ()
(COMMAND "OSMODE" "0")
(COMMAND "trim" "" "F" PAUSE PAUSE  "" "")
David Hall
  • Automatic Duh Generator
Re: Trim Fence
« Reply #1 on: March 02, 2007, 10:43:01 AM »
Off the top of my head, I would say you need to collect points til nil, then feed the trim command points
Re: Trim Fence
« Reply #2 on: March 02, 2007, 10:58:37 AM »
Try
(COMMAND "trim" "" "F")
(WHILE (/= (GETVAR "cmdactive") 0) (COMMAND PAUSE))
Biscuits
Re: Trim Fence
« Reply #3 on: March 02, 2007, 11:43:38 AM »
Thanks Kerry, worked perfect!
Re: Trim Fence
« Reply #4 on: March 02, 2007, 01:52:13 PM »
Here is one I use a lot. It allows multiple trim objects with a 2 point fence.
(defun c:tmm (/ ss pt1 pt2 usercmd *error*)
  ;vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
  ;; error function & Routine Exit
  (defun *error* (msg)
      (not
        (member
          msg
          '("console break" "Function cancelled" "quit / exit abort" "")
    ;;reset all variables here
    (setvar "osmode" useros)
    (setvar "CMDECHO" usercmd)
  ) ; end error function
  (setq usercmd (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq useros (getvar "osmode"))
  (setvar "osmode" 0)
  (while
      (prompt "\nSelect cutting edge(s): ")
      (if (setq ss (ssget))
          (command "._undo" "begin")
          (if (and (setq pt1 (getpoint "\nDraw line to select items to be trimmed: "))
                   (listp ptl)
                   (setq pt2 (getpoint pt1 "\nPick end point. "))
                   (listp pt2))
            (not (command "_.trim" ss "" "F" pt1 pt2 "" ""))
  (command "._undo" "end")
  (*error* "")
) ; end defun
(princ "\nType TMM to start.")
