Author Topic: Help! Can't open a drawing - error message...  (Read 2508 times)
Noodlehoss
« on: April 07, 2005, 02:55:03 PM »
Many hours of work here...can't open the file!
here's the error message:
INTERNAL ERROR:!U:\global\src\ObjectDbx\DB\IMP\src\dbenti.cpp@1130: eWrongObjectType
I hit OK, then it gives me this:
'The instruction at "0x36023b30" referenced memory at "0x401f6010". The Memory could not be "read". Click on OK to terminate the program'
The drawing has an xref which has no problems opening. It has been purged and audited. There is a fair amount of hatching in this drawing. Autosave did not backup the file, nor does a backup copy exist. If anyone has a suggestion, please let me know.
  • Custom Title
« Reply #1 on: April 07, 2005, 02:57:07 PM »
Just for grins, can you insert into a new dwg as a block?
MikePerry
« Reply #2 on: April 07, 2005, 03:04:03 PM »
Hi
Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
ID: TS76782 - INTERNAL ERROR: !U:\global\src\ObjectDbx\DB\IMP\src\dbenti.cpp@1154: eWrongObjectType
If you do not have access to AutoCAD 2004 or higher, please post the drawing file here, then I or someone else will try the Recover command on the drawing file for you.
Have a good one, Mike
Noodlehoss
« Reply #3 on: April 07, 2005, 03:22:14 PM »
...I have tried inserting it into a blank drawing...no luck. I have also tried the Recover command in ACAD 2000...no luck. Mike - can I post the file directly to this board?...it is 1.71M. Thanks for looking into it.
hyposmurf
« Reply #4 on: April 07, 2005, 04:02:17 PM »
Upload it to the lilly pond http://www.theswamp.org/lilly_pond
Noodlehoss
« Reply #5 on: April 07, 2005, 04:05:11 PM »
The drawing has been uploaded to the lilly pond...it is: essex_error.dwg
Thanks!
« Reply #6 on: April 07, 2005, 04:26:33 PM »
hyposmurf
« Reply #7 on: April 07, 2005, 04:36:28 PM »
Or this one. http://www.theswamp.org/lilly_pond/essex_errorfixed.dwg
You beat me to it Ronjop  :) Ive purged the drawing  3 times.
Using the reover command this is what AuitoCAD found:
 69      Blocks audited
Pass 1 8685    objects audited
Pass 2 8685    objects audited
Pass 3 17500   objects audited
Total errors found 4777 fixed 4777
Heres whjat was purged out:
PURGE Purged ADCADD_ZZ.
Purged BORDER.
Purged NFC.
Purged BORD-TXT.
Purged REVISIONS.
Purged SHEET TITLE.
Purged A$C78F32AE1.
Purged SUNTRUST LOGO.
Purged AA_TREE_SINGLE-WAVY-FILLED.
Purged AA_TREE_MS-SIMPLE.
Purged lt_pole_x2.
Purged LIGHTS.
Purged DVIEWBLOCK.
Purged _PLANT_TAGS.
Purged SEC_CUT_1-8.
Purged n_scale_10.
Purged LS_details_notes.
Purged DETAIL_TITLE.
Purged X.
Purged ARCH_96.
Purged STAIR.
Purged DIM_3-32.
Purged LEA_3-32.
Purged L-MISC.
Purged L-WOODSLINE.
Purged L-PAV.
Purged L-STRUC.
Purged L-LIGHTS.
Purged L-LAYOUT.
Purged L-DIM.
Purged L-SPOTS.
Purged L-CON_INT.
Purged L-DRAIN.
Purged L-WATER.
Purged L-IMAGE.
Purged L-G_COV.
Purged L-HIDE.
Purged L-FENCE.
Purged B-R.
Purged B-M.
Purged B-C.
Purged B-8.
Purged B-W.
Purged B-G.
Purged B-H.
Purged B-H2.
Purged XREF.
Purged A-WALL.
Purged A-PATT.
Purged A-WALL-COMP.
Purged A-WALL-ABOVE.
Purged A-WALL-INT.
Purged A-WALL-PRHT.
Purged B-H4.
Purged A-WALL-WT.
Purged A-ANNO-NOTE.
Purged A-WALL-HEAD.
Purged D-TITLE.
Purged OH.
Purged SWAMP_LINE_1.
Purged ELEC_UG.
Purged PHONE_08TVC.
Purged DIMENSION_LINE.
Purged LEADER_LINE.
Purged STREAM_LINE.
Purged C_DASH.
Purged WATER.
Purged DOT2.
Purged D_DASH.
Purged CENTER_LINE.
Purged DASHDOT2.
Purged ltypeshp.shx.
Purged hedge.shx.
Purged FILE.
Purged ROMANC.
Purged ITALICC.
Purged ITALICT.
Purged ATTL_1-4_1.
Purged 3-16_12_ATXT.
Purged DIMTICK.
Purged _ARCHTICK.
Purged _OPEN90.
Purged _DOTSMALL.
Purged TICK.
Purged REVSION.
Purged NFC.
Purged ACAD_ISO14W100.
Purged HIDDEN.
Purged HIDDEN2.
Purged HIDDEN4.
Purged INVISIBLE.
Purged NFC.
Purged SUNTRUST.
Purged A-ANNO-DIMS.
Purged A-ANNO-REV.
Noodlehoss
« Reply #8 on: April 07, 2005, 05:37:41 PM »
Yes! It opens fine. You guys are swamp gods! Guess I should consider an upgrade soon.
This really saved me a lot of redraw time. Much appreciated.  :D
craigr
« Reply #9 on: April 08, 2005, 07:54:27 AM »
Okay, what did you guys do that he couldn't do with his AutoCad?
craigr
EDIT - Never mind. I went and read the AutoDesk link.
craigr
hyposmurf
« Reply #10 on: April 08, 2005, 01:49:26 PM »
Well I tried opening it normaly,didnt work,tried again while hitting Esc to cancel any running commands,that sometimes works.Then I tried renaming the file and opening it,didnt work,so I tried inserting it as a block,still no help.So I ran the recover command and opened it fixed a number of errors,then I purged it.Nothing that complicated.
