I thought it might help to post the code as it stands right now so that we can all be on the same page
CM, I changed a few minor things, just the formatting to the way I use to having it and may be a variable name but all of your methods are exactly the same. I added the = sign in your conditions also.
Please take note of where I placed the selection set code also
Public Sub InstRast()
Dim RastImg As AcadRasterImage
Dim Imgpth As String
Dim Imgname As String
Dim InsertPnt(0 To 2) As Double, scalefactor As Double, RotAngle As Double
ThisDrawing.ActiveSpace = acPaperSpace
Imgpth = ThisDrawing.Path & "\"
Imgname = "FtWashington600.tif"
InsertPnt(0) = 0#: InsertPnt(1) = 0#: InsertPnt(2) = 0#
scalefactor = 1
RotAngle = 0
On Error GoTo Errorhandler
Set RastImg = ThisDrawing.PaperSpace.AddRaster(Imgpth & Imgname, InsertPnt, scalefactor, RotAngle)
RastImg.Name = Left(Imgname, Len(Imgname) - 4)
RastImg.scalefactor = 12
'Move Points
Dim MPointN(0 To 2) As Double 'Negative
Dim MPointP(0 To 2) As Double 'Positive
MPointN(0) = 8: MPointN(1) = 0: MPointN(2) = 0
MPointP(0) = 0: MPointP(1) = 0: MPointP(2) = 0
'Move Raster
RastImg.Move MPointN, MPointP
Dim ImgUR(2) As Double
ImgUR(0) = RastImg.Origin(0) + RastImg.ImageWidth
ImgUR(1) = RastImg.Origin(1) + RastImg.ImageHeight
ImgUR(2) = 0
Dim llpnt As Variant 'lower left point
Dim urpnt As Variant 'upper right point
Dim mdpnt(0 To 2) As Double
Dim ClipPoints(0 To 9) As Double
'Getpoints on raster and check if the user picks within the raster boundaries
Dim Pnts As Boolean
Pnts = False
Do While Pnts = False
llpnt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Select Lower Left Point: ")
urpnt = ThisDrawing.Utility.GetCorner(llpnt, vbCrLf & "Select Upper Right Point: ")
If llpnt(0) >= RastImg.Origin(0) And llpnt(0) <= ImgUR(0) Then
If llpnt(1) >= RastImg.Origin(1) And llpnt(1) <= ImgUR(1) Then
If urpnt(0) >= RastImg.Origin(0) And urpnt(0) <= ImgUR(0) Then
If urpnt(1) >= RastImg.Origin(1) And urpnt(1) <= ImgUR(1) Then
Pnts = True
Else
MsgBox "Pick points inside the raster image"
Pnts = False
End If
Else
Pnts = False
End If
Else
Pnts = False
End If
Else
Pnts = False
End If
Loop
mdpnt(0) = (llpnt(0) + urpnt(0)) / 2 'Midpoint (X) = (The far left picked point + the far right picked point) / 2
mdpnt(1) = (llpnt(1) + urpnt(1)) / 2 'Midpoint (Y) = (The far bottom picked point + the far top picked point) / 2
mdpnt(2) = 0
'Create Selection Set for Raster
Dim Sset As AcadSelectionSet
Set Sset = ThisDrawing.SelectionSets.Add("Image")
Sset.Select acSelectionSetLast
Debug.Print "Selection Set " & "("; Sset.Name; ")" & " was created"
With Sset
End With
'FINITE
'Create a 5 x 5 clip boundary
'clipPoints(0) = 0: clipPoints(1) = 0
'clipPoints(2) = 0: clipPoints(3) = 5
'clipPoints(4) = 5: clipPoints(5) = 5
'clipPoints(6) = 5: clipPoints(7) = 0
'clipPoints(8) = 0: clipPoints(9) = 0
'Clip boundary = 2.5 from the mdpnt of the raster's picked points to the boundary coords.
ClipPoints(0) = mdpnt(0) - 2.5: ClipPoints(1) = mdpnt(1) - 2.5
ClipPoints(2) = mdpnt(0) - 2.5: ClipPoints(3) = mdpnt(1) + 2.5
ClipPoints(4) = mdpnt(0) + 2.5: ClipPoints(5) = mdpnt(1) + 2.5
ClipPoints(6) = mdpnt(0) + 2.5: ClipPoints(7) = mdpnt(1) - 2.5
ClipPoints(8) = mdpnt(0) - 2.5: ClipPoints(9) = mdpnt(1) + -2.5
'DYNAMIC
'Clip boundary = picked points (llpnt and urpnt)
' ClipPoints(0) = llpnt(0): ClipPoints(1) = llpnt(1)
' ClipPoints(2) = llpnt(0): ClipPoints(3) = urpnt(1)
' ClipPoints(4) = urpnt(0): ClipPoints(5) = urpnt(1)
' ClipPoints(6) = urpnt(0): ClipPoints(7) = llpnt(1)
' ClipPoints(8) = llpnt(0): ClipPoints(9) = llpnt(1)
'Clip boundary = user defined (uniform) size
'Dim Bndsize As Double
'Bndsize = ThisDrawing.Utility.GetReal("What size boundary would you like?: ")
'ClipPoints(0) = mdpnt(0) - (Bndsize / 2): ClipPoints(1) = mdpnt(1) - (Bndsize / 2)
'ClipPoints(2) = mdpnt(0) - (Bndsize / 2): ClipPoints(3) = mdpnt(1) + (Bndsize / 2)
'ClipPoints(4) = mdpnt(0) + (Bndsize / 2): ClipPoints(5) = mdpnt(1) + (Bndsize / 2)
'ClipPoints(6) = mdpnt(0) + (Bndsize / 2): ClipPoints(7) = mdpnt(1) - (Bndsize / 2)
'ClipPoints(8) = mdpnt(0) - (Bndsize / 2): ClipPoints(9) = mdpnt(1) + -(Bndsize / 2)
'Clip the image
RastImg.ClipBoundary ClipPoints
'Enable the display of the clip
RastImg.ClippingEnabled = True
ThisDrawing.SelectionSets.Item("Image").Delete
Errorhandler:
If Err.Description = "File access error" Then
If MsgBox("Can not find image file") Then
Exit Sub
End If
End If
