Unfortunately it doesn't work that way.. The
GetContentType Method returns one of the following enumerables:
acCellContentTypeBlock
acCellContentTypeField
acCellContentTypeUnknown
acCellContentTypeValue
Which means that when you use
GetCellValue Method you'll either get a vlax-vbString variant or a vlax-vbEmpty one.. but not a vlax-vbObject. (atleast thats the result from the quick test I did on a TypeField, TypeField and TypeBlock contenttype).
However for your case I'd suggest to use the
SetCellTextStyle Method, meaning that you create and manipulate your own TextStyle Object, and in the end just apply it to the acad_table/AcDbTable object.
Another way would be to manipulate the cell itself via methods like:
GetBackGroundColor GetContentColor GetTextHeight GetTextStyle GetCellStyle GetCellTextHeight.. and so on.
BTW You might find this
sub useful, for dealing with table cells.
