Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Sam on March 04, 2013, 02:24:22 AM
Dear sir,
please see this offset code it s ok or any modification this code
or
What is difference between below code
In all these examples the command continues beyond the scope of the function. This is not good programming practice. My suggestions:
(command "_.offset" 150 pause pause
Dear Sir,
Thx for guidance
Thx for Reply
Dear Sir,
i am combing of varies offset this code ok or any suggestion
If you test your code in a new drawing you will find that the nested functions only become available after their parent functions have been called. This means that you have to use the c:100 function at least once for the c:150 function to become available. And the c:150 function must be called for the c:230 function to become available. And of the three functions only c:230 will behave properly.
The question is what are you trying to do? You should not nest functions without a good reason.
If you want to use an 'offset template' function, consider this example:
(defun OffsetTemplate
(dist
(dist
[/quote]
Dear Sir,
Thx for help
i am study
