Author Topic: [ wip ] Select nested  (Read 14929 times)
Spike Wilbury
Re: [ wip ] Select nested
« Reply #15 on: March 14, 2009, 06:25:24 PM »
Tim,
Nice job as always.  8-)
In a quick test, the ENTER key does not end the selection process although 'Right Click' does.
Also the Undo command does not work after objects have been erased from the block.
I tried the routine, nice one Tim (as normal) - I been using the Block Editor feature for this (I know), your routine is a great alternative - since it won't required a 2nd (or more) block editor opening when the nest entities are inside of a nest block, and so on.. (hope it make sense). :)
Hi Alan,
Just need a Regen after the operation.
« Last Edit: March 14, 2009, 06:46:33 PM by LE »
« Reply #16 on: March 14, 2009, 09:11:45 PM »
Oh, thanks Luis, the regen did the trick with the undo. I should have though of that. :oops:
cjw
« Reply #17 on: March 15, 2009, 12:16:43 AM »
Tim,
Thank you sharing.
Nice work!
It's amazing, fantastic !
« Reply #18 on: March 16, 2009, 12:29:43 PM »
Thanks everyone for the kind words, and the testing.  I'm still trying to make it better, as per Joe's comments about xrefs.  I think I have a way to do it.  Now all I need is the time to write it.
« Reply #19 on: March 18, 2009, 12:06:04 PM »
Updated code in the first post, and listed what has changed.
