Author Topic: Erase extend line  (Read 1946 times)
flowera
Erase extend line
« on: July 05, 2006, 01:42:18 AM »
Hi all,
How to erase extended line using AutoLISP command.
I have attached drawing file.
flowera
Re: Erase extend line
« Reply #1 on: July 05, 2006, 01:44:25 AM »
Hi
This is drawing file
Andrea
« Reply #2 on: July 05, 2006, 09:25:23 AM »
Keep smile...
PHX cadie
« Reply #3 on: July 05, 2006, 10:46:03 AM »
Flowera
 If you are "attaching" a file, while you are in the reply page, hit "additional options" then browse to your file. If you "preview" the attachment will be lost and you will have to re attach your file
For one reason or another your dwg is not there.
« Last Edit: July 05, 2006, 11:36:00 AM by PHX cadie »
Acad 2013 and XM
