Author Topic: list comparison  (Read 11124 times)
daron
list comparison
« on: July 07, 2005, 03:28:23 PM »
I have some lists
(1 11)
(5 11 45)
I want to compare these lists to return t or nil if either number in the first list is = to any number in the second list. I know this can be done, but I'm frying my brain trying to remember how. :evil: Please help. I've tried different variations of member, mapcar, and foreach, but all attempts have resulted nil when it's obvious that there is a match.
list comparison
« Reply #1 on: July 07, 2005, 03:33:52 PM »
Consider --
(mapcar
   '(lambda (x) (and (member x '(5 11 45))))
   '(1 11)
Now rewrite it as a function that takes two arguments.
list comparison
« Reply #2 on: July 07, 2005, 03:37:01 PM »
Wasnt this just mentioned? ...Yep! Heres my example from the post.  (I'll post my example code and then i'll go get the link for ya.)
(defun test (lst-c lst-m / inlist)
  (defun inlist (? lst)
    (and (member ? lst)) )
    ((inlist (car lst-c) lst-m)
     (alert "Found a match")
     (test (cdr lst-c) lst-m))
    ( T (cond
          ((<= (length lst-c) 1)
           "End of list reached"
          ( T (test (cdr lst-c) lst-m))))) )
daron
list comparison
« Reply #3 on: July 07, 2005, 03:37:02 PM »
which is exactly what I intend to do. Thank you. I'm still trying to get my mind around the various ways to use member, mapcar and lambda.
list comparison
« Reply #4 on: July 07, 2005, 03:38:48 PM »
Holly cow. You guys move fast!
Well anyways, heres the link i promised.
EDIT: *sigh* (I forgot the link!??!)
http://www.theswamp.org/phpBB2/viewtopic.php?t=5656
list comparison
« Reply #5 on: July 07, 2005, 03:39:43 PM »
Quote from: daron
My pleasure. Don't forget about the power in the apply, catch-all-apply, foreach etc. functions too.
daron
list comparison
« Reply #6 on: July 07, 2005, 03:43:46 PM »
Here's the answer to your request:
(defun comparison (grlist complist)
     (mapcar
 '(lambda (x) (and (member x complist)))
 grlist
John, funny you posted that code. I was searching before posting, but I think my mind was so wrapped up in how I was failing, that I didn't think it would apply. Thanks to both of you.
daron
list comparison
« Reply #7 on: July 07, 2005, 03:45:26 PM »
MP, I'll have to look at the apply's, but I was also trying foreach with no luck. End of the day stress I think and lack of coding for months.
list comparison
« Reply #8 on: July 07, 2005, 03:47:49 PM »
Here's one that uses foreach & member...
(defun inList? (l1 l2 / res)
  (foreach x l1
    (if (member x l2)
      (setq res t)
  res
list comparison
« Reply #9 on: July 07, 2005, 05:06:27 PM »
Daron, *lol* Yeah I do that too.
But, that code I posted was just a stupid example. Its not very efficient, I was just trying to make a point with that code. The point being that the task can be solved about a million diff ways but if you write down what you want to do; you can code the solution almost the same way as you wrote it down.
For instance: Take what our friend "StarGazer" wrote in the request.
> What I want it to do is grab the first item in the just dump it into a
> list as the first element. Then reading the next line in I want to
> compare it to the list to see if it's the same, if it is then just
> skip it. If not append it to the list. Then go to the next line and
> compare that one to the list. Now that list can be just one or several
> elements that need to be compared.
Now take a look at my code. Im doing almost exactly what he said. (Basicy I translated his words into Autolisp code.)
Okay, im done ranting/taching/preaching/etc for da-day.
LE
Re: list comparison
« Reply #10 on: July 07, 2005, 05:18:28 PM »
This will return the position and the item, and stop evaluating once one item is found.
(setq lst1 '(1 11))
(setq lst2 '(5 11 45))
(vl-some '(lambda (i / pos)
   (if (setq pos (vl-position i lst1))
     (list pos i)))
lst2)
list comparison
« Reply #11 on: July 07, 2005, 05:36:43 PM »
Wasn't Daron looking for a result that indicated the status of each member in the first list, like '(nil t)? Did I misunderstand (again)?
LE
list comparison
« Reply #12 on: July 07, 2005, 05:46:39 PM »
Quote from: MP
Do not know Michael, to me he wants to find a match an item being on both lists.
Well, I'll wait for his reply.
list comparison
« Reply #13 on: July 07, 2005, 05:55:23 PM »
Hey that's very cool..
_$ (setq lst1 '(1 11 3 6 7))
(setq lst2 '(5 21 18 7 11 45))
(1 11 3 6 7)
(5 21 18 7 11 45)
_$ (vl-some '(lambda (i) (member i lst1)) lst2)
(7)
list comparison
« Reply #14 on: July 07, 2005, 05:57:04 PM »
Welll ... I went back and read his question and I think I am wrong, maybe he wants an overall result of nil or t ro reflect whether any item in the first list exists in the second.
Something like --
(vl-some
   '(lambda (item) (and (member item list2)))
    list1
BTW, does LE = Luis Esquivel?
