Code Red > OpenDCL
PictureBox Not Showing Picture
(1/1)
DeeGeeCees_V.2.0:
I'm just starting out with OpenDCL and am trying to get an image loaded into a form. This should work but it doesn't and I can't figure out why. I posted this over at the AD forum as well and have had a bit of help from the good folks over there, hence the saved string variables and hard coded paths.
The DCL opens with an empty picturebox then I get an error after closing.
What am I missing?
--- Code: ---(defun c:ODCT ( / fileName imgName)
(command "_OPENDCL")
(setq fileName "C:\\PRD\\Apps\\LISP\\ODCT.ODCL")
(setq imgName "C:\\PRD\\Apps\\LISP\\TestLogo.png")
((not (findfile fileName)) (alert (princ "\nProject File not found.")))
((not (findfile imgName)) (alert (princ "\nImage File not found.")))
(t
(dcl_Project_Load fileName T)
(dcl-Form-Show ODCT/Form1)
(dcl-PictureBox-LoadPictureFile ODCT/Form1/PictureBox1 imgName T)
(prompt "\nODCT Complete.")
--- End code ---
Error:
Navigation
[0] Message Index
Go to full version
