Author Topic: FILLET acad2015 &16  (Read 1071 times)
Bryco
FILLET acad2015 &16
« on: August 06, 2015, 11:46:03 AM »
Using
Command: FILLET
Current settings: Mode = TRIM, Radius = 0.2500
Select first object or [Undo/Polyline/Radius/Trim/Multiple]: P
with A POLY with both lines and arcs I have some very bad results.
see dwg.  I am using the vanilla version of acad mechanical.
Anyone else have these problems?
ChrisCarlson
Re: FILLET acad2015 &16
« Reply #1 on: August 06, 2015, 11:53:30 AM »
Yup, been present for some time. The fillet is attempting to apply the fillet at the line segment - arc segment.
