Code Red => AutoLISP (Vanilla / Visual) => Topic started by: KewlToyZ on August 19, 2009, 02:08:17 PM
I am running this routine for building the layers in a drawing.
http://www.theswamp.org/index.php?topic=8763.30
2007-2009 verticals it worked terrific.
For some reason in 2010 it hangs up often for 5-25 seconds when I fire the command from a button call.
It works fine after I call the routine from the command line, so I am not sure why it loads so slowly from a button.
For example
In a button call:
^C^C_LRS;E-POWR-CIRC;^C^C(ticks "electrical/E-Tick Mark - POWR-3")
it seemed simple enough. But unless I ran the LRS command from the command prompt once, it tanked slowly.
Then I got curious...
^C^C_LRS;E-POWR-CIRC;(ticks "electrical/E-Tick Mark - POWR-3")
Command fired quickly after closing and opening the file again.
So I closed out of AutoCAD completely to see if it really was the cancels causing the slow commands...
I guess it was, the problem seems to be gone after 4 different test files.
I'm curious why?
I wondered if it could have something to do with the Legacy command scripting capability they put into 2010?
I'm curious if anyone else has ran into this?
Hmmm it still hangs on an initializing call in 2010.
Once it has ran it is fine but the first call takes a few seconds to run.
2007-2009 it runs fine, 2010 no errors it just runs slow on a first call.
OK did a minor re-write:
(defun c:LRS ( / inslayer)
; Menu Command example: ^C^C_LRS;E-CLOK
; Thanks to Kerry Brown, CAB, and the crew at TheSwamp
; http://www.theswamp.org/index.php?topic=8763.0
(vl-load-COM)
(princ "\n Layer requested (?): ")
(princ inslayer)
;(princ "")
(defun myLayers()
; Load the default NCS layers routine and run it..
(autoload "LRD" '("LRD"))
(c:LRD)
(prompt "\n NCS layers loaded! ....\n")
; Set the layer requested as current
(command "clayer" inslayer)
; If the command is fired empty prompt for layer name
(if (or (null inslayer)(= inslayer nil))
(setq inslayer (getstring "\n Enter Layer Name: "))
(myLayers)
) ; end progn
) ; end if
; If the layer name is not present load all layers
(if (not (tblobjname "layer" inslayer))
(myLayers)
) ; end progn
) ; end if
;Turn off command line responses
(command "CMDECHO" 0) ;DO NOT CHANGE THIS LINE
; Get the current layer
(setq userLayer (getvar "clayer"))
; purge other layers
; Thanks to Lee Mac for this
(princ "\n Purging empty file entries.......")
(setq doc (vla-get-ActiveDocument
(vlax-get-acad-object)))
(repeat 3 (vla-purgeall doc))
(princ "\n File Purge Complete !!!!!!......")
; Print the layer name
(prompt "\n LRS Set to layer: ................ ")
(princ userLayer)
(princ "\n")
(command "CMDECHO" 1) ;DO NOT CHANGE THIS LINE
(princ "\n LRS (layer set) routine is loaded !!!")
