Author Topic: How the Explode non-scale of block objects ?  (Read 1689 times)
hunterxyz
« on: May 01, 2009, 07:41:16 PM »
This block is non-scale.
block is not Explode,
Requests master help to answer, thanks ~
Bob Wahr
Re: How the Explode non-scale of block objects ?
« Reply #1 on: May 01, 2009, 08:20:47 PM »
If I understand correctly, you are asking if it's possible to explode a block that is not scaled uniformly.  That depends on what version you are running.  You didn't used to be able to explode a non-uniform block, but have been able to since 2007.  If that's your problem, attach your drawing and tell me which block and I can explode it for you.
hunterxyz
« Reply #2 on: May 02, 2009, 10:24:56 AM »
Figure
Bob Wahr
« Reply #3 on: May 02, 2009, 03:10:10 PM »
OK, that's what I thought.  Are you just wanting them exploded, or are you looking for a lisp solution that will explode all non-uniform blocks?
