Code Red => AutoLISP (Vanilla / Visual) => Topic started by: e2002 on April 15, 2005, 04:25:01 AM
use vla-FieldCode can get Text ,Mtext obejct's Fieldcode ,but invalid in Attrib
I can see no way of retrieving that info. The docs only mention FieldCode method for TEXT, MTEXT.
#<VLA-OBJECT IAcadAttributeReference 0c3ac424>
; Methods supported:
; ArrayPolar (3)
; ArrayRectangular (6)
; Copy ()
; Delete ()
; GetBoundingBox (2)
; GetExtensionDictionary ()
; GetXData (3)
; Highlight (1)
; IntersectWith (2)
; Mirror (2)
; Mirror3D (3)
; Move (2)
; Rotate (2)
; Rotate3D (3)
; ScaleEntity (2)
; SetXData (2)
; TransformBy (1)
; Update ()
FieldCode??? Is that a new one???
Why don't you explain what you're trying to do and maybe we could help you come up with a solution.
we known command "ddedit" can edit Text , MText ,Dimension , Insert include Attributes
about 2 years ago , i writen a program like ddedit , that can direct edit the Attributes in a Insert object.
but now my AutoCAD upgrade to 2005/6 , and i use the new Field feature in the Attribs .
i want to enhance my old program to support the Field.
if ActiveX can't get the FieldCode , i have to try normal LISP (entget..... )
this is the code :
(setq esl (nentsel)
en (car esl)
el (entget en)
en_1 (cdr (assoc 360 el))
el_1 (entget en_1)
en_2 (cdr (assoc 360 el_1))
el_2 (entget en_2)
en_3 (cdr (assoc 360 el_2))
el_3 (entget en_3)
en_4 (cdr (assoc 360 el_3))
el_4 (entget en_4)
You get the actual Fieldcode with that?
I recall when I played with the 2005 beta that it was convoluted similar to that, I'll see if I can find my code (in my backups, as I just rebuilt my pc) ...
