Author Topic: Turn MText AutoCAPS on  (Read 1779 times)
Guest
« on: December 01, 2006, 11:01:11 AM »
I'm looking for a way to turn AutoCAPS on for MText (either LSP or VBA).
TIA.
daron
Re: Turn MText AutoCAPS on
« Reply #1 on: December 01, 2006, 11:11:10 AM »
If you right-click in the editor, you can set autocaps in there. If I remember correctly, it will hold globally. If that's not enough for you, Keith built a capsman.exe
Have a look for it. You should be able to find it.
M-dub
Guest
« Reply #3 on: December 01, 2006, 11:23:44 AM »
Yeah I know but....
Since we've upgraded to LDT 2007, the AutoCAPs don't seem to "stick".  Somehow, someway, something is turning them off.  I might just use a reactor.  I dunno.  Thanks.  I'll also take a quick peek at the capsman.exe.
TimSpangler
  • CAD Naked!!
« Reply #4 on: December 01, 2006, 12:38:17 PM »
When was AutoCAPS introduced (version ? 2000? )
ACA 2015 - Windows 7 Pro
Guest
« Reply #5 on: December 01, 2006, 12:57:57 PM »
Somewhere around that time I believe.
« Reply #6 on: December 01, 2006, 08:36:49 PM »
AutoCAD 2000 introduced the AutoCaps for MText, but I have found it unreliable, even as late as R2007.
The capsman.exe loads into resident memory and simply watches for changes in the topmost window. If AutoCAD is the topmost window it automatically turns CAPSLOCK on. If you open certain other programs it will automatically turn it off. If you right click on the icon in the taskbar you will be able to configure the program. (at least I think I included that feature in the executable uploaded here) You can also exit the program by right clicking on it in the task bar and selecting exit. Otherwise it hides itself back to the taskbar.
I think if you do a quick search for it here, you will find the command line switches for quiet loading so you can put a link to it in the startup suite or the run key in the registry. (I don't remember what they were at the moment)
