Author Topic: Text is Null  (Read 2439 times)
David Hall
  • Automatic Duh Generator
Text is Null
« on: August 18, 2008, 03:20:34 PM »
Is there any property or telltale way to know if you ahve null text in your drawing?  The only thing I can think of is if the contents contain a space only, as in " "
Any other ideas of how to find stupidity running rampant in the office?
Re: Text is Null
« Reply #1 on: August 18, 2008, 03:28:07 PM »
(ssget "x" '((0 . "TEXT")(1 . ""))
(ssget "x" '((0 . "TEXT")(1 . " "))
(ssget "x" '((0 . "TEXT")(1 . "  ")) 'to infinity and beyond
or you could turn on qtext and regen ... "null" text should show up as points in the drawing
Re: Text is Null
« Reply #2 on: August 18, 2008, 03:39:39 PM »
Atook
  • AKA Tim
Re: Text is Null
« Reply #3 on: August 18, 2008, 04:14:55 PM »
maybe something along the lines of:
if len(Trim(objtext.textstring))=0 then
 ' fight for whirled peas
end if
David Hall
Re: Text is Null
« Reply #4 on: August 18, 2008, 04:41:05 PM »
Thank you to all three!!! I used a combined versioin of what you guys posted and it works great
rogue
Split peas? or Splitting hairs?
« Reply #5 on: August 19, 2008, 12:35:25 PM »
If any of you have done database programming, you might remember there is a difference between an empty string ("") and a NULL one.
And I believe any other string that contains 1-to-many space characters (Chr(32)) isnt Null, or an empty string.
One of the ways to check for Nulls is to read the variables in as variants, and check for IsNull. And then, if it is, add an empty string to it ("") to convert to string.
Glenn R
Re: Text is Null
« Reply #6 on: August 19, 2008, 03:56:03 PM »
Whilst that would be true for an RDBMS, which AutoCAD is NOT, a simpler idea might be to use regular expressions...
