Author Topic: (challange - newbie) in between two numbers  (Read 7702 times)
« Reply #15 on: January 05, 2005, 02:24:25 PM »
...you just told them the answer!?
whdjr
« Reply #16 on: January 05, 2005, 02:29:26 PM »
All that means is that as a programmer you need to code it properly.  duh.. :D
SMadsen
« Reply #17 on: January 05, 2005, 03:15:57 PM »
All that means is that programmers in Seattle are leaving big security holes in MSIE :D
Oh, no one saw my contribution? :lol:
« Reply #18 on: January 05, 2005, 03:22:35 PM »
precisely ... The rules were followed .... the numbers were given and the code was written to match the numbers, not the other way around. Of course, it IS good practice to code to many scenarios, BUT if you quantify the syntax and code to that, the overhead is significantly lower.
It is always best to code to the simplest form, otherwize you end up creating bloatware just like Microsoft, I remember when Windows could be loaded on a 100MB drive and have tons of extra space... now you are required a minimum of 2GB just to install windows where 8Mb of memory was sufficient for most programming 10 years ago, now you almost MUST have 512Mb. The issue has to do with the size of the code and the gobs of things put in the code that are designed to circumvent user stupidity.
To "fix" the code so the user can enter the range values .. use this:
(defun inbetween (@t @l @u)
  (and(< (min @l @u) @t)(> (max @l @u) @t))
« Reply #19 on: January 05, 2005, 04:07:02 PM »
To determine if x is between a and b ...
(< a x b)
What am I missing?
SMadsen
« Reply #20 on: January 05, 2005, 04:53:30 PM »
Quote from: MP
What am I missing?
Sequence of arguments is all. Not necessarily an issue as much as a convenience, I would say.
« Reply #21 on: January 05, 2005, 05:18:18 PM »
Cool MP, good to see you.
Here is your code the other way. :)
(defun between (mid start end) (< start mid end))
(between 5 1 10)
(between 1 3 10)
(between 5 8 10)
(between 5 5 10)
T
nil
nil
nil
« Reply #22 on: January 05, 2005, 09:43:19 PM »
Hey MP, Hows life been treating ya?
Well this thread was about the newbies, but it kinda got overrun a bit.
