Author Topic: Macro  (Read 4455 times)
krampaul82
Macro
« on: January 18, 2013, 12:38:50 PM »
Good Afternoon
Is it possible to open an Excell Document from a MSword vba Application?
code so far
Sub Get_Req_for_WEBS()
' Get_Req_for_WEBS
' This Will Open A WEBS Information sheet Specific to Mark
 ChangeFileOpenDirectory "C:\gtc_proj\VBA_word\Excel_2007_doc\Mark\"
    Documents.Open FileName:= _
        "C:\gtc_proj\VBA_word\Excel_2007_doc\Mark\EXCEL.*" _ This is where i would like to launch an Excel File
        , ConfirmConversions:=False, ReadOnly:=False, AddToRecentFiles:=False, _
        PasswordDocument:="", PasswordTemplate:="", Revert:=False, _
        WritePasswordDocument:="", WritePasswordTemplate:="", Format:= _
        wdOpenFormatAuto, XMLTransform:=""
    'Windows("Document1").Activate
    End
any help appreciated
Matt__W
  • I like my water diluted.
Re: Macro
« Reply #1 on: January 18, 2013, 12:49:10 PM »
Autodesk Expert Elite
krampaul82
Re: Macro
« Reply #2 on: January 18, 2013, 01:04:49 PM »
Thanks for the Nudge Matt 8-)
krampaul82
Re: Macro
« Reply #3 on: January 18, 2013, 03:03:51 PM »
Good afternoon
Found this code:
Sub OpenExcel_Letter_of_trans()
Public Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
strDir = "V:\gtc_proj\VBA_word\Excell_2007_doc\"
strFile = "_Master Letter of Transmittal.xls"
ShellExecute 0, "OPEN", strDir & strFile, "", strDir, 1
does not work  does not like the Declare function any ideas?
Matt__W
Re: Macro
« Reply #4 on: January 18, 2013, 03:22:58 PM »
Try this instead...
krampaul82
Re: Macro
« Reply #5 on: January 18, 2013, 03:40:51 PM »
It says the object invoked has disconnected from its clients.
krampaul82
Re: Macro
« Reply #6 on: January 18, 2013, 04:02:47 PM »
Matt
I got it to work! it was user error! Imagine that!
Thank you for your help
Mark 8-)
Matt__W
Re: Macro
« Reply #7 on: January 20, 2013, 06:23:30 AM »
You're welcome!   :kewl:
