Author Topic: WPF Controls In PaletteSet  (Read 4698 times)
dousmell
« on: July 30, 2008, 07:11:25 PM »
I'm having some issues w/ VS2008 and AutoCAD:
•   When I run code using VS2008 in debug works flawlessly.
•   When NETLOAD module independently of VS2008 => Crash and burn. :(
Can someone please help?
internal class paletteSetLibrary
        // {31258470-74A3-4b73-AF2F-EB5342684526}
        private static Guid PaletteSetId = new Guid("31258470-74A3-4b73-AF2F-EB5342684526");
        public PaletteSet paletteSet { get; set; }
        public void Initialize()
            paletteSet = new PaletteSet("Library", PaletteSetId)
                                 Visible = true,
                                 Style = PaletteSetStyles.Snappable | PaletteSetStyles.ShowAutoHideButton,
                                 WindowState = FormWindowState.Normal,
                                 KeepFocus = true
            var libraryViewer = new LibraryViewer();
            var elementHost = new ElementHost(){Dock = DockStyle.Fill};
            elementHost.Child = libraryViewer;
            paletteSet.Add("Details", elementHost);
Re: WPF Controls In PaletteSet
« Reply #1 on: July 30, 2008, 10:45:16 PM »
I don't know, have you tried copying the referenced acad dll into the same folder as the dll you are loading?
Might be worth a shot.
- John Carmack
- J.R.R. Tolkien
tjr
« Reply #2 on: July 30, 2008, 11:38:36 PM »
Could this have something to do with the different versions of the .net runtime? Wpf is v3 and acad defaults to v2 doesn't it?
« Reply #3 on: July 30, 2008, 11:44:36 PM »
Make sure you have at least .net V2 with the service pack
dousmell
« Reply #4 on: July 30, 2008, 11:52:22 PM »
Whether the references are "CopyLocal" or not I get this:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.InvalidOperationException: The calling thread cannot access this object because a different thread owns it.
   at System.Windows.Threading.Dispatcher.VerifyAccess()
   at System.Windows.Threading.DispatcherObject.VerifyAccess()
   at System.Windows.DependencyObject.GetValue(DependencyProperty dp)
   at System.Windows.Input.Keyboard.IsFocusable(DependencyObject element)
   at System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew)
   at System.Windows.Input.KeyboardDevice.Focus(IInputElement element)
   at System.Windows.UIElement.Focus()
   at System.Windows.Forms.Integration.ElementHost.OnGotFocus(EventArgs e)
   at System.Windows.Forms.Control.WmSetFocus(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Integration.ElementHost.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ActiveXImpl.System.Windows.Forms.IWindowTarget.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3031 (netfxsp.050727-3000)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
    Assembly Version: 17.1.0.0
    Win32 Version: 17.1.219.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AcdbMgd.DLL
msvcm80
    Assembly Version: 8.0.50727.1434
    Win32 Version: 8.00.50727.1434
    CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.1434_none_d08b6002442c891f/msvcm80.dll
acmgd
    Win32 Version: 17.1.51.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/acmgd.DLL
AecSpaceOffsetRulesManager
    Assembly Version: 5.5.256.0
    Win32 Version: 5, 5, 256, 0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecSpaceOffsetRulesManager.DLL
AecSpaceOffsetStandardBasic
    Win32 Version: 5.5.256.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecSpaceOffsetStandardBasic.DLL
AecBaseMgd
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecBaseMgd.DLL
AecSpaceOffsetStandardBasic.resources
    Assembly Version: 5.5.235.0
    Win32 Version: 5, 5, 235, 0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AecSpaceOffsetStandardBasic.resources.DLL
AecArchMgd
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecArchMgd.DLL
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
AecSpaceOffsetStandardBOMA
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Space%20Calculation%20Standards/AecSpaceOffsetStandardBOMA.dll
AecSpaceOffsetStandardBOMA.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AecSpaceOffsetStandardBOMA.resources.DLL
AecSpaceOffsetStandardDIN
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Space%20Calculation%20Standards/AecSpaceOffsetStandardDIN.dll
AecSpaceOffsetStandardDIN.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AecSpaceOffsetStandardDIN.resources.DLL
AecSpaceOffsetStandardSIS
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Space%20Calculation%20Standards/AecSpaceOffsetStandardSIS.dll
AecSpaceOffsetStandardSIS.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AecSpaceOffsetStandardSIS.resources.DLL
AecDtlDb
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecDtlDb.DLL
AecDtlDbUI
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecDtlDbUI.DLL
AecDtlDbLib
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecDtlDbLib.DLL
AcInfoCenterConn
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AcInfoCenterConn.DLL
AdInfoCenter
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AdInfoCenter.DLL
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Autodesk.Interop.AcInetEngine
    Assembly Version: 17.1.51.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Autodesk.Interop.AcInetEngine.DLL
AdInfoCenter.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AdInfoCenter.resources.DLL
Accessibility
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
6fmce9vq
Autodesk.Interop.WSCommCntr1
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Autodesk.Interop.WSCommCntr1.DLL
Autodesk.Interop.WebServices1
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Autodesk.Interop.WebServices1.DLL
System.Web.Services
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
shwurmkx
BGA.CAD.Library
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/Administrator/Documents/Visual%20Studio%202008/Projects/BGA.CAD.Library/BGA.CAD.Library/bin/Debug/BGA.CAD.Library.dll
WindowsFormsIntegration
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.6920.1413 built by: SP1Beta1
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsFormsIntegration/3.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
    CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationFramework.Classic
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Classic/3.0.0.0__31bf3856ad364e35/PresentationFramework.Classic.dll
UIAutomationProvider
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationProvider/3.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
UIAutomationTypes
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationTypes/3.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
System.Runtime.Serialization
    Win32 Version: 3.0.4506.2060 (SP1Beta1.030422-0100)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.ServiceModel
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll
AcLayer
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AcLayer.DLL
AcMgdShared
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AcMgdShared.DLL
acmgdinternal
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/acmgdinternal.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AcLayer.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
« Reply #5 on: July 30, 2008, 11:55:32 PM »
Also try sticking the assembly/assemblies in the acad folder
dousmell
« Reply #6 on: July 30, 2008, 11:56:32 PM »
Now this may be a dumb question: If I already have .NET V3.5 do I still need to install V2.0? Also, why does the code run in DEBUG? I'm trying to bind to a web service using WPF which is really easy. But the code won't run in ACAD. I'm really glad you all are awake right now.
Thanks very much for your help.
P.S. Do you guys have these posts as RSS? I would love to read all this where ever I am.
dousmell
« Reply #7 on: July 31, 2008, 12:04:33 AM »
I did try to isolate the problem by using an empty WPF usercontrol to see if it was due to the WPF Interop that was causing the problem. The problem does continue. I also tried an empty ElementHost control with no WPF associated with it and it does load fine. So I've narrowed it down to the interaction w/ WPF.
Does anyone know if there is a way I can get WPF to use the same thread as Acad? I also tried Thread.ApartmentState=ApartmentState.STA and no effect.
I'm guessing that somehow when the code is running in visual studio that VS has some configuration some where that makes WPF behave properly within ACAD but I have no clue to find out why that is. Or is it that Microsoft just makes Debug run code perfectly to mislead us on purpose?
tjr
« Reply #8 on: July 31, 2008, 12:13:02 AM »
I'm almost certain this is your problem:
mscorlib
WPF is a new feature of .NET 3.0. Try forcing .NET 3.5 or whatever in autocad's app.config (or whatever that file is called).
tjr
« Reply #9 on: July 31, 2008, 12:21:32 AM »
Scratch that thought, I see you have WPF loaded further down.
« Reply #10 on: July 31, 2008, 03:52:15 AM »
can you post a sample solution for us to try?
dousmell
« Reply #11 on: July 31, 2008, 01:31:27 PM »
Hello all,
I've got my solution reduced to the essentials. I would be indebted to you all if you could have a go at this and give me your thoughts.
Thanks again,
