Author Topic: OVLIDE a new online lisp editor  (Read 12129 times)
Matthew H
Re: OVLIDE a new online lisp editor
« Reply #30 on: March 12, 2018, 05:40:30 PM »
Andrea,
I also added some notes to my above post.
Andrea,
This is a really useful tool! Though I was confused, When installed it says 15 Trial days left.
When I go to "http://ovlide.com/pricing#". They all say $0/Month and the website doesn't seem fully completed.
Can you add some clarification?
*Note: EntGetUI's dialog box position is always reset to the far side when using two monitors.
When having a drawing open and using the EntGetUI command, starting another drawing causes the EntGetUI command to become non existent, this is also the case when having more then one drawing open and initializing the EngGetUI command then initializing the command on another open drawing.
Thank you,
Matthew H
Thank you,
Matthew H
Andrea
« Reply #31 on: March 12, 2018, 05:53:55 PM »
oh... ok thank you..
what would you like to have as result ?
do you want that dialog box keep last position and size
or reset to middle of screen ?
I will put new reactor when switching drawing and refresh dialog box.
Keep smile...
« Reply #32 on: March 12, 2018, 06:13:33 PM »
Just following your good work.
Would it be too difficult to make the box location a user selectable setting?
Andrea
« Reply #33 on: March 12, 2018, 10:36:56 PM »
sure....all can be possible :)
Keep smile...
ifncdylan
« Reply #34 on: March 14, 2018, 01:46:08 AM »
Wow! I'm partial to VLIDE myself, but that EntGet GUI looks amazing! I'll have to download this and give it a try :)
Andrea
« Reply #35 on: March 14, 2018, 12:27:51 PM »
Hi MJfarrell,..
I've made few test on dialog position,...
the thing is that the dialog actually keep the last position and size for each session of AutoCAD,..
so the request is that you need to set dialog position and size when starting AutoCAD,...right ?
Keep smile...
Andrea
« Reply #36 on: March 14, 2018, 12:28:13 PM »
Keep smile...
Andrea
« Reply #37 on: March 14, 2018, 01:09:18 PM »
Just let you know,..
New version will have Registred application list.  :)
Keep smile...
Andrea
« Reply #38 on: March 16, 2018, 10:36:38 AM »
new version of ENTGETUI
ENTGETUI v.18.074
Keep smile...
