Author Topic: How to correctly Insert block in Table for 2011  (Read 3318 times)
Jeff H
« on: February 10, 2011, 02:37:32 AM »
In 2011 you get the obsolete warning if you use
Table.SetBlockTableRecordId() Method------- It does work
How do you use the recomended Table.Cells[row,column].Contents.BlockTableRecordId
Had problems getting it to work. Possibly the Contents part. Have not found much info on it.
kaefer
Re: How to correctly Insert block in Table for 2011
« Reply #1 on: February 10, 2011, 05:37:59 AM »
It would appear that there's no support for multiple Contents with CellContentTypes.Block.
Jeff H
« Reply #2 on: February 12, 2011, 03:13:26 PM »
I was not calling  Table.Cells[i, j].Contents.Add();
That got it working
Table.Cells[i, j].Contents[0].BlockTableRecordId = ObjectID;
kaefer
« Reply #3 on: February 13, 2011, 06:13:58 PM »
That got it working
Same problem here. To correct myself: Of course you can have multiple Contents with ContentTypes.Block.
Now it works. See the example below (simple block counter again).
But, but, but... How would you get around the obsolete NumRows and NumColumns properties?
        [CommandMethod("BLKCNTTBL", CommandFlags.UsePickSet)]
        public static void BlkCntTbl()
            Editor ed = AcApp.DocumentManager.MdiActiveDocument.Editor;
            Database db = AcApp.DocumentManager.MdiActiveDocument.Database;
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.MessageForAdding = "Select blocks (or enter for all): ";
            pso.AllowDuplicates = false;
            SelectionFilter sf =
                new SelectionFilter(new TypedValue[]{ new TypedValue(0, "INSERT") });
            PromptSelectionResult psr = ed.GetSelection(pso, sf);
            if (psr.Status == PromptStatus.Error) psr = ed.SelectAll(sf);
            if (!(psr.Status == PromptStatus.OK) && (psr.Value.Count > 0)) return;
            string title =
                "Blocks in " +
                System.IO.Path.GetFileNameWithoutExtension(db.Filename);
            Dictionary<string, int> dict = new Dictionary<string, int>();
            using(Transaction tr = db.TransactionManager.StartTransaction())
                foreach(SelectedObject so in psr.Value)
                    BlockReference br = (BlockReference)tr.GetObject(so.ObjectId, OpenMode.ForRead);
                    if(dict.ContainsKey(br.Name)) dict[br.Name] += 1;
                    else dict.Add(br.Name, 1);
                PromptPointResult pr = ed.GetPoint("\nEnter table insertion point: ");
                if(pr.Status == PromptStatus.OK)
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    BlockTableRecord cspace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Table tb = new Table();
                    tb.Position = pr.Value;
                    tb.NumRows = 2; // "Use Table.Rows.Count instead."
                    tb.NumColumns = 2;  // "Use Table.Columns.Count instead."
                    tb.TableStyle = db.Tablestyle;
                    TableStyle ts = (TableStyle)tr.GetObject(tb.TableStyle, OpenMode.ForRead);
                    double textHeigth = ts.TextHeight(RowType.DataRow);
                    tb.Columns[0].Width = textHeigth * 24;
                    tb.Columns[1].Width = textHeigth * 8;
                    int y = 0;
                    tb.Cells[y, 0].TextString = title;
                    y += 1;
                    tb.Cells[y, 0].TextString = "Block name";
                    tb.Cells[y, 1].TextString = "Count";
                    y += 1;
                    foreach(KeyValuePair<string,int> entry in dict)
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[entry.Key], OpenMode.ForRead);
                        if (!(btr.IsLayout || btr.IsAnonymous))
                            tb.InsertRows(y, textHeigth * 4, 1);
                            tb.Cells[y, 0].ContentLayout = CellContentLayout.StackedHorizontal;
                            CellContentsCollection cc = tb.Cells[y, 0].Contents;
                            cc.Add();
                            cc[0].TextString = entry.Key;
                            cc.Add();
                            cc[1].BlockTableRecordId = bt[entry.Key];
                            tb.Cells[y, 1].TextString = entry.Value.ToString();
                            y += 1;
                    tb.GenerateLayout();
                    cspace.AppendEntity(tb);
                    tr.AddNewlyCreatedDBObject(tb, true);
                tr.Commit();
Have fun, Thorsten
kaefer
« Reply #4 on: February 14, 2011, 05:50:35 AM »
Here's a pic for BLKCNTTBL, with a drawing from http://images.autodesk.com/adsk/files/blocks_and_tables_-_metric.dwg
Jeff H
« Reply #5 on: February 14, 2011, 07:20:48 PM »
My understanding you use InsertRows & InsertColumns
You can set the settings for a row and use InsertRowsAndInherit(index where to start, index to copy settings, # of rows)
I have no idea why this keeps making the last row a title.
I used Tuples just messing around no real reason
       [CommandMethod("CreateSymbolLegend")]
            public void CreateSymbolLegend()
                List<Tuple<ObjectId, string, string>> blockinfo = new List<Tuple<ObjectId, string, string>>();
                Database db = doc.Database;
                Editor ed = doc.Editor;
                using (Transaction trx = db.TransactionManager.StartTransaction())
                    BlockTable bt = db.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
                    BlockTableRecord btrMs = (BlockTableRecord)bt[BlockTableRecord.ModelSpace].GetObject(OpenMode.ForRead);
                    foreach (ObjectId objId in bt)
                        BlockTableRecord btr = trx.GetObject(objId, OpenMode.ForRead) as BlockTableRecord;
                        if (btr.IsLayout) continue;
                        blockinfo.Add(Tuple.Create(btr.ObjectId, btr.Name, btr.Comments));
                    Tuple<ObjectId, string, string>[] blockArr = blockinfo.ToArray();
                    Table tbl = new Table();
                    tbl.TableStyle = db.Tablestyle;
                    tbl.Position = Point3d.Origin;
                    tbl.InsertRows(0, 1,  1);
                    tbl.Rows[0].Style = "Data";
                    tbl.InsertRowsAndInherit(1, 0, blockArr.Length - 2);
                    tbl.InsertColumns(0, 1, 1);
                    for (int i = 0; i < blockArr.Length; i++)
                        tbl.Cells[i, 0].Contents.Add();
                        tbl.Cells[i, 0].Contents[0].BlockTableRecordId = blockArr[i].Item1;
                        tbl.Cells[i, 1].Value = blockArr[i].Item3;
                    tbl.GenerateLayout();
                    btrMs.UpgradeOpen();
                    btrMs.AppendEntity(tbl);
                    trx.AddNewlyCreatedDBObject(tbl, true);
                        trx.Commit();
« Last Edit: February 14, 2011, 07:26:53 PM by Jeff H »
kaefer
« Reply #6 on: February 15, 2011, 03:37:06 AM »
Thanks, that does the trick nicely.
Because your're inserting your data rows before the pre-existing title row, maybe?
So I'd go with something like this instead:
                   TableStyle ts = (TableStyle)tr.GetObject(tbl.TableStyle, OpenMode.ForRead);
                    tbl.Cells[0, 0].TextString <- "title";
                    tbl.InsertRows(1, textHeigth * 2,  1);
                    tbl.Rows[1].Style <- "_Data"; // i18n!
                    tbl.InsertRowsAndInherit(1, 1, blockArr.Length - 1);
                    tbl.Columns[0].Width <- textHeigth * 16;
                    tbl.InsertColumnsAndInherit(1, 0, 1);
Cheers
Jeff H
« Reply #7 on: February 15, 2011, 03:56:14 AM »
Cheers
Thank you, Thank you
As usual you were dead on.
