CAD Forums => CAD General => Topic started by: MSTG007 on November 04, 2015, 11:13:53 AM
I have been looking for a way to implement check lists within drawings. I have created a word doc that has what needs to be shown on a title sheet. Is there a way that I can transfer that check list to a drawing so I can check off the items that need to be on the check list?
sure....one could link a spreadsheet to a table on a Layout or somewhere in modelspace....
Ok I can follow that. Let me brainstorm on that idea. Thanks a bunch!
Ok I have been thinking about this alittle bit more. How hard would it be to create a DCL Interface that has a list with check marks next to them, then in the drawing it can retain the values that are checked next time the drawing is opened by myself or another machine?
If this check list is static, why don't you just create a table & insert it in the drawing? Add a column where you place an 'X' when you finish the task.
Is it purely standards based or a check list of things to do?
Here are some of the things I am thinking. Right now we just came up with a list that things need to be on each drawing. I was thinking of a way a user types in a command, up pops a box with the items that need to be on that sheet. The user can check box or what ever to say that the item is on the sheet.
Maybe I can create an invisible attributed block that can have the list and store the check boxes of what is currently done in the drawing.
As the user saves the file it can be opened by someone else to see where the previous user left off.
I get the table idea. User will need to zoom to table and copy the (X) down. But the user will need to remember and not to delete the table accidently.
I get the excel link table, but I do not think with that type of lag in each drawing is smart.
Still thinking...
Linked Table will do this
Still thinking...
Put on it's own LAYOUT TAB
Catching a case of the clevers here: each entry in the list is a dynamic block insert. Attribute for what is to be checked off, visibility state for a checked/not checked box. Content of block constructed to be constructed such that the not-checked visibility state objects are on a plotting layer, checked-state objects are on a non-plotting layer.
hey, you might be on to something.... That is genius.
Mark's MyXNotes.lsp routine comes to mind.
