Code Red => .NET => Topic started by: nobody on June 02, 2019, 07:35:53 AM
Possible to run the importer with different shape files more than once in a session? Trying to import shape files from 2 different paths. It works fine when I run them in a single operation, but if I try to run them separately it seems Map hates me.
Thanks!
Thanks!
Nevermind. Appears I can declare/run the import engine multiple times.
Appears it was just having trouble with the table naming when I separated the activities. Simple test for name fixed it < :idiot2:
