CAD Forums => CAD General => Topic started by: ELOQUINTET on March 02, 2004, 06:38:08 PM
i have this macro and i am trying to fix the scale and rotation. i want my image to be inserted with a scale of 7.9036 and with a rotation of -90. how would i modify my macro to acheive this?
(command "-layer" "n" "0-IMAGE" "c" "WHITE" "0-IMAGE" ) ;setvar clayer "0-IMAGE";_imageattach
seem to be that _imageattach allways invoke the dialog box.
I do not know if there is a way to avoid the dialog box to show off.
You cannot use imageattach in this scenario you should use image....
Now to get the rest of the command parameters passed, you will need to..
1) Call image with a lisp function in your button... i.e. (command "image" ......)
2) Determine what the order of operation is for the image command. I don't use image (or imageattach for that matter) so right off the top of my head I cannot tell you.
3) Probably right after the attach command is issued, you will need to specify insertion points and scales... you can use \ to pause (i think) and then hard code the scale...
Something like this ...
(command "image" "a") ;\ 90 7.9036
You will probably have to tweak it since I have not tested it....
image invoke the dialog box too, a diferente but a dialog .
The trick would be how to tell acad not to show te dialog and acept command line input.
I had tryed all way , changing attdia , ccmddia, and cmdactive, Iset it to 0
but it still show the dialog box.
Here ya Dan.
(defun get-mspace ()
(vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
(defun get-img-file ()
(getfiled "Browse for Image file: " "" "" 8)
(defun c:img-insert (/ ms imgfile ins-pt image-obj)
(setq ms (get-mspace)); modelspace object
(if (setq imgfile (get-img-file))
(if (setq ins-pt (getpoint "\nInsertion Point: "))
(setq image-obj
(vla-AddRaster ms
imgfile
(vlax-3D-point ins-pt)
7.9036
(* pi 1.50)
(if image-obj
(if (not (vlax-object-released-p image-obj))
(vlax-release-object image-obj)
Forgot the layer part!
(command "layer" "make" "0-IMAGE" "color" 7 "" "")
(setq image-obj
(vla-AddRaster ms
imgfile
7.9036
(* pi 1.50)
(if image-obj
I have had a bit of time to peruse this...
This works as well...
(command "image" "a" "imagename" pause "7.9036" "-90")
If you need to browse for the image, use....
(command "image" "a" (getfiled "Image to insert" "" "jpg" 8) pause "7.9036" "-90")
If you use the command -image and set filedia to 0 the dialogue doesn't pop-up.
Ron :D
Hi Ronjop, I forget that the image was a file, and I did not consider the filedia as the variable to change. :oops:
Thanks for it :)
hey mark i was using what i asked for for jpgs at home but i am trying to adapt your lisp to tiff files here at work. i figured out that to change the file type to browse for i had to change the 8 to 14. it's working but my question is why would it be assigning an anonymous name "OAImg1082920496" to it rather than the actual name of the scan "a-430"? here's what i have:
(getfiled "Browse for Image file: " "" "" 14)
(defun c:I12 (/ ms imgfile ins-pt image-obj)
(setq image-obj
(vla-AddRaster ms
imgfile
387.25
(* pi 1.50)
(if image-obj
it's not a big deal i was just wondering if it's an easy fix or no?
Don't use 14 Dan.
ok changed it back to 8. for some reason when i had it as 8 before when i browsed it wasn't showing any tiffs so i thought this would fix that. now they are showing up with the 8, who knows? it's still giving the image a funky name and i can't see where it does that :?:
what is the exact name of the file you are trying to insert?
A-430 for this example. it varies though
A-430.?
is that your answer mark or were you guessing what i'd say?
Does the A-430 have an extension? Like .tif of .tiff
yeah .tif sorry bout that
HI,
Im having a problem extruding a non-circular shape around a helix. The shape I need to extrude is rectangular. Whenever I extrude a rectangle around a polyline helix (into solid form) the rectangle gets twisted. The rectangle starts off perpendicular to the axis of the helix and ends up twisted at an angle. I checked a number of furums and noticed other people had problems with helix's. Perhaps Autocad can't do this. If this is the case, is there a relatively easy way aound this. I'd like to point out that I'm not interested in extruding a circle. Id apreciate some feedback on this,
:shock:
when posting a new post hit new thread not post a reply ok
Dan, did you ever get that little program to work for your .tif files? It works for me just fine!
johnjoe
Take a look Here (http://theswamp.org/phpBB2/viewtopic.php?t=1147)
ummm no mark its still giving it a dummmy name. i was mainly using it for something i'm doing at home so its not such a big deal. i have a huge video collection and am making inserts for my video cases. some i already have a volume and when i scan and insert it to use as a template for volume 2 i don't want to have to input the info. it would be nice because i considering zipping and burning them to disc. have you burned drawings with images to disc. is there a problem with it losing the path. i have everything in the same folder which i will burn. anyway that's the status report thanks for askin :P
I believe as long as you maintain the same path structure you'll be fine.
