Author Topic: Dynamic Intelligent Leader !  (Read 181113 times)
architecture68-raff
  • Strange things are afoot at the Circle-K.
Re: Dynamic Intelligent Leader !
« Reply #150 on: September 09, 2009, 09:59:38 AM »
Hi Andrea,
does not work:
Pick Text location...
bad argument type: 2D/3D point: nil
At this point,...what kind of object entity you have selected ?
I am getting this error too no matter what kind of object I select, but I am using Autocad 2005.  Although I don't remember what the exact reason is, I seem to recall an explanation as to why your other dynamic routines (dhatch, dcloud, etc.) will not function correctly in older versions.  Perhaps this is part of his problem?
Fixed !  thanks..
was an error on local variables.  ;-)
DiLEADER 2.2.4
Can't speak for zanze02, but it seems to work as advertised for me now.
Thanks!  Great tool.
Chicago, Illinois
ADT 2005, Revit Architecture 2009, Sketchup 7
Hugo
« Reply #151 on: September 09, 2009, 11:31:45 AM »
Hallo Andrea
Bei mir sind immer die Pfeile zu gross.
Was muss ich da einstellen. (siehe Bild)
Andrea
« Reply #152 on: September 09, 2009, 12:16:19 PM »
Hallo Andrea
Blick auf die Variablen und mir sagen, was sie sind:
DIMASZ
DIMSCALE
DIMTXT
Keep smile...
Hugo
« Reply #153 on: September 10, 2009, 12:47:32 AM »
Hallo Andrera
DIMASZ 2.50
DIMSCALE 35.00
DIMTXT 2.50
Danke
Aerdvark
« Reply #154 on: September 10, 2009, 01:30:46 AM »
Hi Andrea,
It certainly works great now !!
A few days ago you said you felt like you were done with this lisp.
Well it turns out that you were not  :-P
As many others I once again say: great job !
Andrea
« Reply #155 on: September 10, 2009, 08:34:07 AM »
Hallo Andrera
DIMASZ 2.50
DIMSCALE 35.00
DIMTXT 2.50
Danke
Hallo Hugo, ich verstehe nicht, warum es nicht funktioniert. Könnten Sie mir Ihr Bild?
Ich lade Sie auch zu Ihrem Text, bevor sie sie auf theswamp übersetzen.
http://translate.google.com/#
danke.
Aerdvark....
Thank you I realy appreciate. DiLEADER grow up with your comments ans suggestions.
Keep smile...
Shade
« Reply #156 on: September 10, 2009, 09:44:06 AM »
This is a great little program and I have been following the progress for quite sometime now.
Trying out the odd new versions as they become available.
I have one little problem though, that I thought was part of the original program.
When I move the leader text, the leader(s) do no follow, like when you more the objects (ie. circle, line).
Is the text supposed to stay stationary and only the object can move and the leader reacts to the new position?
Myself and other at my office like the idea of the lisp, but we tend to move the leader text more then the objects the leader is pointing to.
We move the text more to fit in a viewport when detailing, if you are curious why.
Is it possible to put a reactor on the text also?
Keep up the great work I look forward to the next version, that is if there is one......
Shade :mrgreen:
Andrea
« Reply #157 on: September 10, 2009, 10:02:50 AM »
Shade :mrgreen:
Hi shade,
are you using DilEdit ?
Keep smile...
Hugo
« Reply #158 on: September 10, 2009, 10:13:54 AM »
Hallo Andrea
Habe ein Zip angehängt mit einer DWG.
Danke
Andrea
« Reply #159 on: September 10, 2009, 11:52:56 AM »
This Drawing doesn't work on 2008 but work on 2010..
I have set the same Dim variable on a blank drawing...
I have explode the leader and insert on that drawing to know if the problem come form the textsize or the arrowsize..
it seem to be the arrow size....it keep always the non-override dimstyle.
Bug on this drawing or a variable I don't know ?
If some of you can give this a try..
thanks.
Keep smile...
Pad
« Reply #160 on: September 10, 2009, 12:24:36 PM »
ah right i see.  I was selecting them after creating them and wondering why they weren't moving as in your animations.
I should have read the instructions. Diledit works like a charm.
MeasureUp
« Reply #161 on: September 13, 2009, 09:07:30 PM »
Hi Andrea,
does not work:
Fixed !  thanks..
DiLEADER 2.2.4
Hi Andrea,
Thanks for your sharing.
I tried your code but found a problem.
It made a number of copies of leaders when I moved the mouse.
Please see the attachements.
Thanks again.
zanze02
  • Mosquito
« Reply #162 on: September 14, 2009, 03:27:23 AM »
Hi....
First,..welcome to theswamp !  :-)
Hi Andrea,
does not work:
  ;;Create leader point
(if (> (distance int urpoint) (distance int ulpoint))....
"urpoint" is nil and "ulpoint" is nil
some variable are local and will aways return nil at the end if they was nil
into dilconfig function and createdildialog function
"(strcat (getvar "SAVEFILEPATH") "dlconfig.dcl")"
is "D:\\Tempdlconfig.dcl"
adding "\\" write the correct file name path
"(strcat (getvar "SAVEFILEPATH")"\\" "dlconfig.dcl")"
is "D:\\Temp\\dlconfig.dcl"
I do not understand..why you don't have the "\\" at the end...
I checked the values of variables with Debug Visual Lisp Editor
I changed the path using the tab "File" from "Options", this removes the "\" at the end.
I use "Autodesk Map 3D 2006 - Italiano SP1"
My first message was at "Reply #116"
Regards and i apologize for my not perfect English
I will try the new version as soon as possible
zanze02
  • Mosquito
« Reply #163 on: September 14, 2009, 04:16:00 AM »
If not set as current WCS, at the prompt "Pick Text location..." text is positioned away from the cursor.
on DILEDIT command, the problem remains when using a new UCS.
« Reply #164 on: September 14, 2009, 07:35:37 AM »
Andrea,
I normally use this when dealing with filepaths:
(setq fpath "C:\\Lee Mac")
(or (eq "\\" (substr fpath (strlen fpath)))
    (setq fpath (strcat fpath "\\")))
 :wink:
