Author Topic: Accelerators  (Read 1881 times)
ML
Accelerators
« on: November 19, 2004, 09:12:42 AM »
Does anyone have an idea why these accelerators aren't working?
They were working just fine until a week or so ago.
I can't figure it out
Thank you
***ACCELERATORS
      [CONTROL+SHIFT+"C"]^C^Cstart;Calc;
      [ CONTROL+SHIFT+"E"]^C^Cstart;explorer;
Accelerators
« Reply #1 on: November 19, 2004, 10:07:47 AM »
Try
[CONTROL+SHIFT+"C"]^C^Cstart Calc
[ CONTROL+SHIFT+"E"]^C^Cstart explorer
Accelerators
« Reply #2 on: November 19, 2004, 10:29:03 AM »
***ACCELERATORS
I don't see anything wrong with them. Might want to try this for opening explorer...I use it everyday.
^C^C^(startapp "explorer" (strcat "/e," ^M;(getvar "dwgprefix")));
Ron
ML
Accelerators
« Reply #3 on: November 22, 2004, 06:52:14 AM »
Thanks CAB
Thanks Ron
I will first try to remoce the enters (;) and see what happens.
I have seen that aproach also Ron. That would be a good alternative but I was hoping to just do accelerators for the above 2 things
ML
Accelerators
« Reply #4 on: November 22, 2004, 03:25:57 PM »
Cab,
Does not work either :(
The weird thing is that the same code works at home  :cry:
