Author Topic: Multiple copy command  (Read 4603 times)
TJAM51
« on: September 15, 2004, 07:57:56 AM »
I know that the following toolbar command will do multiple copies but how would you do it in lisp
copy;\;m;;
SMadsen
« Reply #1 on: September 15, 2004, 08:19:28 AM »
(command "COPY" pause "" "M" pause)
If it's part of a multiple task routine, you might want to include a loop like
(while (> (getvar "CMDACTIVE") 0)
  (command pause)) .. or something like that.
Beware that the multiple option has been changed with 2005, so that multiple copying is now the default.
M-dub
« Reply #2 on: September 15, 2004, 08:22:59 AM »
Quote from: SMadsen
FINALLY!!!  :)  :twisted:
« Reply #3 on: September 15, 2004, 08:24:19 AM »
well an old trick is:
(command "copy" pause ""  "m")
SMadsen
« Reply #4 on: September 15, 2004, 08:26:49 AM »
Quote from: Keith
Right, the last pause in my post is redundant (unless some needy code follows)
TJAM51
« Reply #5 on: September 15, 2004, 08:30:56 AM »
I tried this
(DEFUN C:cm ()
and received this
Command: cm
copy
Select objects: 1 found
Select objects: mulitple
*Invalid selection*
Expects a point or
Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P
revious/Undo/AUto/SIngle
; error: Function cancelled
Select objects:
Specify base point or displacement, or [Multiple]: *Cancel*
TJAM51
« Reply #6 on: September 15, 2004, 08:37:38 AM »
I also tried this
and received this
Command: cm
copy
*Invalid selection*
Expects a point or
SMadsen
« Reply #7 on: September 15, 2004, 08:49:43 AM »
TJ, where does the "mulitple" come from? (and what language is it? :) )
TJAM51
« Reply #8 on: September 15, 2004, 08:52:50 AM »
I am using 2001. I am wanting to use the multiple command so the multiple is a user input.......russian maybe
SMadsen
« Reply #9 on: September 15, 2004, 08:56:24 AM »
Nah, that would be mulitsje  :)
Try this
(defun C:CM ()
  (cond ((setq ss (ssget))
         (command "_COPY" ss "" "Multiple")
TJAM51
« Reply #10 on: September 15, 2004, 09:01:35 AM »
In the voice of Elvis Presley
thank you very much
SMadsen
« Reply #11 on: September 15, 2004, 09:07:05 AM »
:dood:
