Author Topic: Can a table be exported to Excel?  (Read 2058 times)
waterharbin
« on: February 08, 2012, 08:55:15 AM »
Hello,everyone. Can a table be exported to Excel?
we define a table in AutoCAD :
Dim TableEnt As New Autodesk.AutoCAD.DatabaseServices.Table()
Then, we can launch Excel :
Imports Microsoft.Office.Interop
Public Sub exportToExcel()
        Dim xlApp As Excel.Application
        Dim xlWorkBook As Excel.Workbook
        Dim xlWorkSheet As Excel.Worksheet
        Dim misValue As Object = System.Reflection.Missing.Value
        Try
            xlApp = New Excel.ApplicationClass
            xlWorkBook = xlApp.Workbooks.Add(misValue)
            'Fixed:(Microsoft.Office.Interop.Excel.Worksheet)
            xlWorkSheet = DirectCast(xlWorkBook.Sheets("sheet1"), Excel.Worksheet)
            xlWorkSheet = DirectCast(xlWorkBook.ActiveSheet, Excel.Worksheet)
            'changing the name of active sheet
            xlWorkSheet.Name = "My Exported DataSet"
            xlApp.Visible = True
        Catch ex As Exception
            MessageBox.Show(ex.StackTrace() + ex.Message())
        End Try
But how to select a table in AutoCAD, and then expoted the texts to Excel.
 Is this possible? I have no idea of this. Is there anyone who has done this before?
By the way, To lanuch Excel, we will need to  add a reference to the Microsoft Excel object library.Do it liks this:
Right click on your project and select Add Reference menu. After that go to COM tab and select and add Microsoft Excel 12.0 object library
« Last Edit: February 08, 2012, 09:06:16 AM by waterharbin »
kaefer
Re: Can a table be exported to Excel?
« Reply #1 on: February 08, 2012, 09:42:48 AM »
Who haven't done this before? See e.g. this message by gile for a nice example, look for WriteXls().
You do not want to go down that route. To be independent of specific installed versions (here 12.0), use late binding instead.
waterharbin
« Reply #2 on: February 10, 2012, 02:22:14 AM »
Hello,Kaefer.I have heard late binding before.But I don't known how to do it. Can you teach me? Thanks.
gile
  • Marseille, France
« Reply #3 on: February 10, 2012, 04:13:30 AM »
You can see here an example of late binding using to read or write Excel files.
