Author Topic: display a list in a dialog box  (Read 1762 times)
psuchewinner
« on: May 10, 2010, 08:36:07 AM »
Say I have a list:
("AAAAA";"BBBBB";"CCCCC")
and I want to display it in a dialog box, on separate lines.....how do I do it?
Re: display a list in a dialog box
« Reply #1 on: May 10, 2010, 08:51:01 AM »
psuchewinner
« Reply #2 on: May 10, 2010, 10:31:31 AM »
That will get me to where I need to go.  Thanks for the "nudge".
« Reply #3 on: May 10, 2010, 11:09:11 AM »
Please ask if you need any more assistance.
psuchewinner
« Reply #4 on: May 10, 2010, 11:23:38 AM »
Im stumped again.  I can get the dialog up and display stuff ok but what I am actually trying to do is list the "support path directories" in a dialog box.  I can get them in a list ok by accessing them through the "prefs" object, but in the resulting list they are separated by semicolons.  How do i filter the semicolons out and show each directory separately?
  (setq AcadObject (vlax-get-acad-object))
  (setq PrefsObject (vlax-get-property AcadObject 'Preferences))
  (setq TabNameObject (vlax-get-property PrefsObject 'Files))
(setq ThePath (vlax-get-property TabNameObject 'SupportPath))
« Reply #5 on: May 10, 2010, 11:26:01 AM »
Something like:
(defun StringParser (str del)  ; Lee Mac
  (if (setq pos (vl-string-search del str))
    (cons (substr str 1 pos)
          (StringParser (substr str (+ pos 1 (strlen del))) del))
    (list str)))
(StringParser "Lee;Mac;is;cool" ";")
==>  ("Lee" "Mac" "is" "cool")
Oh BTW,
You can get at the Support Paths using:
(getenv "ACAD")
psuchewinner
« Reply #6 on: May 10, 2010, 12:00:06 PM »
Thats what im after...thanks!
« Reply #7 on: May 10, 2010, 12:05:16 PM »
You're very welcome :-)
efernal
« Reply #8 on: May 10, 2010, 03:12:56 PM »
Here is an example:
(SETQ lista (LIST "AAA" "BBB" "CCC" "1" "2" "3" "n"))
(START_LIST "list" 3)
(MAPCAR 'ADD_LIST lista)
(END_LIST)
e.fernal
e.fernal
