Author Topic: Label polylines elevation  (Read 3607 times)
Scott
« on: October 14, 2006, 01:04:43 AM »
Hello everyone,
I'm sure this has been addressed in the past, but I can't seem to find what I need when searching, so here we go.
I need a lisp routine that will allow me to pick a polyline and label the elevation of said polyline along the polyline at user specified intervals.  I'm using MAP 5.
Any help is greatly appreciated.
Scott
Re: Label polylines elevation
« Reply #1 on: October 14, 2006, 09:25:41 AM »
Scott, I thought MAP could do that with an existing command? I don't have MAP
but am remembering a past thread. Maybe it was Civil I'm remembering.
I'm sure I've seen more on the subject but this is all I could find this morning.
http://www.theswamp.org/index.php?topic=10412.msg132910#msg132910
http://www.theswamp.org/index.php?topic=12704.msg155663#msg155663
Scott
« Reply #2 on: October 14, 2006, 12:00:47 PM »
The routine to label the polyline nodes with the elevation is pretty much what I'm looking for, but I would like to be able to set the distance to label the polyline and have the elevation parallel to the polyline.
Thanks for the input,
Scott
« Reply #3 on: October 14, 2006, 05:41:44 PM »
You need to look at this command.
(vlax-curve-getPointAtDist curve-obj dist)Can you modify the lisp?
Scott
« Reply #4 on: October 14, 2006, 07:39:08 PM »
I have no clue how to modify lisp.  I wouldn't know where to begin.
Scott
Scott
« Reply #5 on: October 17, 2006, 10:20:05 AM »
Thanks for the help, but I have found a solution.
Scott
« Reply #6 on: October 17, 2006, 10:31:07 AM »
You're welcome Scott, glad you got it solved.
