Author Topic: =>[Challenge]<= Nested rectangles  (Read 4890 times)
Jeremy
« on: May 12, 2013, 07:40:59 PM »
Thought we needed a fun task to do. Consider the illustration of rectangles within rectangles. We will assume that each rectangle is a dynamic block that has been stretched out as needed. We will also assume that all rectangles are drawn so that they do not intersect or touch each other. I want the user to be able to select all of the rectangles and get nested parentheses indicating the nesting relationship between the rectangles. The ordering will be determined going from left to right and top to bottom. Let the integers represent the enames of the rectangles. I want to get back a list like this
(1 (2)(3 (4)(5))(6 (7 (8 ))))
where each pair of parentheses represents one of the rectangles and the integers are the enames of the appropriate rectangles.
Jeremy
Re: =>[Challenge]<= Nested rectangles
« Reply #1 on: May 12, 2013, 07:46:40 PM »
Sorry folks, meant to post this in the general section but forgot that I wasn't there before I hit the button. Could a moderator move this please?
« Reply #2 on: May 13, 2013, 07:29:55 AM »
Here is my attempt:
  1. (defun c:rord ( / _inside-p _massoc _process ent inc itm lst ref sel sub tmp vtl )
  2.
  3.     (defun _inside-p ( ll1 ur1 ll2 ur2 )
  4.         (apply 'and (mapcar '<= ll2 ll1 ur1 ur2))
  5.     )
  6.
  7.     (defun _massoc ( key lst )
  8.         (if (setq itm (assoc key lst))
  9.             (cons (cdr itm) (_massoc key (cdr (member itm lst))))
  10.         )
  11.     )
  12.
  13.     (defun _process ( lst ref / itm nst out )
  14.         (while (setq itm (car lst))
  15.             (setq lst (cdr lst))
  16.             (if (setq nst (cdr (assoc itm ref)))
  17.                 (setq out (cons (cons itm (_process nst ref)) out)
  18.                       lst (vl-remove-if '(lambda ( x ) (member x nst)) lst)
  19.                 )
  20.                 (setq out (cons itm out))
  21.             )
  22.         )
  23.         (reverse out)
  24.     )
  25.
  26.     (if (setq sel (ssget '((0 . "LWPOLYLINE") (90 . 4) (-4 . "&=") (70 . 1))))
  27.         (progn
  28.             (repeat (setq inc (sslength sel))
  29.                 (setq ent (ssname sel (setq inc (1- inc)))
  30.                       vtl (_massoc 10 (entget ent))
  31.                       tmp (cons (cons ent (mapcar '(lambda ( x ) (apply 'mapcar (cons x vtl))) '(min max))) tmp)
  32.                       lst (cons ent lst)
  33.                 )
  34.             )
  35.             (foreach x1 tmp
  36.                 (foreach x2 (vl-remove x1 tmp)
  37.                     (if (apply '_inside-p (append (cdr x2) (cdr x1)))
  38.                         (setq sub (cons (car x2) sub))
  39.                     )
  40.                 )
  41.                 (setq ref (cons (cons (car x1) sub) ref)
  42.                       sub nil
  43.                 )
  44.             )
  45.             (_process (vl-sort lst '(lambda ( a b ) (> (length (assoc a ref)) (length (assoc b ref))))) ref)
  46.         )
  47.     )
  48. )
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #3 on: May 13, 2013, 12:30:31 PM »
my version:
  1. (defun eea-test (/ f l)
  2.   (defun f (l a b c)
  3.     (cond ((not l)
  4.            (vl-remove nil
  5.                       (cons (if b
  6.                               (cons (last a) (f (cdr (reverse b)) (last b) nil nil))
  7.                               (cddr a)
  8.                             )
  9.                             (if c
  10.                               (f (cdr (reverse c)) (last c) nil nil)
  11.                             )
  12.                       )
  13.            )
  14.           )
  15.           ((vl-every (function <=) (car a) (caar l) (cadr a)) (f (cdr l) a (cons (car l) b) c))
  16.           ((f (cdr l) a b (cons (car l) c)))
  17.     )
  18.   )
  19.   (if (setq l (ssget '((0 . "LWPOLYLINE") (90 . 4) (-4 . "&=") (70 . 1))))
  20.     (progn (setq l (vl-sort (mapcar (function (lambda (a) (append (acet-geom-extents a) (list a))))
  21.                                     (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex l)))
  22.                             )
  23.                             (function (lambda (a b) (<= (caar a) (caar b))))
  24.                    )
  25.            )
  26.            (f (cdr l) (car l) nil nil)
  27.     )
  28.   )
  29. )
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: May 13, 2013, 12:34:31 PM »
Here is my attempt:
  2. ...
Hi Lee!
Your version gives replays for nested entities...  :-(
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: May 14, 2013, 07:56:40 AM »
optimized my version:
  1. (defun eea-test-1 (/ f l)
  3.     (cond ((not l)
  4.            (cons (if b
  5.                    (cons (last a) (f (cdr (reverse b)) (last b) nil nil))
  6.                    (cddr a)
  7.                  )
  8.                  (if c
  9.                    (f (cdr (reverse c)) (last c) nil nil)
  10.                  )
  11.            )
  12.           )
  13.           ((vl-every (function <=) (car a) (caar l) (cadr a)) (f (cdr l) a (cons (car l) b) c))
  14.           ((f (cdr l) a b (cons (car l) c)))
  15.     )
  16.   )
  17.   (if (setq l (ssget '((0 . "LWPOLYLINE") (90 . 4) (-4 . "&=") (70 . 1))))
  18.     (progn (setq l (vl-sort (mapcar (function (lambda (a) (reverse (cons a (acet-geom-extents a)))))
  19.                                     (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex l)))
  20.                             )
  21.                             (function (lambda (a b) (<= (caar a) (caar b))))
  22.                    )
  23.            )
  24.            (f (cdr l) (car l) nil nil)
  25.     )
  26.   )
  27. )
ps. Why, this topic in the section "CAD General", and not "AutoLISP (Vanilla / Visual)"?
« Reply #6 on: May 14, 2013, 08:47:21 AM »
my version:
  1. (defun f (l a b c)
  2.     (cond ((not l)
  3.            (vl-remove nil
  4.                       (cons (if b
  6.                               (cddr a)
  7.                             )
  8.                             (if c
  10.                             )
  11.                       )
  12.            )
  13.           )
  14.           ((vl-every (function <=) (car a) (caar l) (cadr a)) (f (cdr l) a (cons (car l) b) c))
  15.           ((f (cdr l) a b (cons (car l) c)))
  16.     )
  17.   )
Superb method Evgeniy!
The recursion technique reminds me of this:-)
Here is my attempt:
  2. ...
Hi Lee!
It worked in all of my tests, but I agree that the method is not as robust as yours.
Careful Evgeniy:
  1. (reverse (cons a (acet-geom-extents a))) =/= (append (acet-geom-extents a) (list a))
Also, since you are aiming for optimisation, why use:
ssnamex is known to be very slow...
« Last Edit: May 14, 2013, 08:58:36 AM by Lee Mac »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: May 14, 2013, 09:14:04 AM »
Draw three rectangles, first inside, then outside (see attachments)...
((<Entity name: 7ffffce5810> <Entity name: 7ffffce5760> (<Entity name: 7ffffce5800> <Entity name: 7ffffce5760>)))
« Reply #8 on: May 14, 2013, 09:25:33 AM »
Thanks!
This should fix the problem, but it is ugly compared with your solution:
  1. (defun c:rord ( / _inside-p _massoc _process _sort enx han inc itm lst ref sel sub tmp vtl )
  2.
  5.     )
  6.
  10.         )
  11.     )
  12.
  17.                 (setq out (cons (cons itm (_process (_sort nst ref) ref)) out)
  19.                 )
  21.             )
  22.         )
  23.         (reverse out)
  24.     )
  25.
  26.     (defun _sort ( lst ref )
  27.         (vl-sort lst '(lambda ( a b ) (> (length (assoc a ref)) (length (assoc b ref)))))
  28.     )
  29.
  30.     (if (setq sel (ssget '((0 . "LWPOLYLINE") (90 . 4) (-4 . "&=") (70 . 1))))
  31.         (progn
  32.             (repeat (setq inc (sslength sel))
  33.                 (setq enx (entget (ssname sel (setq inc (1- inc))))
  34.                       vtl (_massoc 10 enx)
  35.                       han (cdr (assoc 5 enx))
  36.                       tmp (cons (cons han (mapcar '(lambda ( x ) (apply 'mapcar (cons x vtl))) '(min max))) tmp)
  37.                       lst (cons han lst)
  38.                 )
  39.             )
  40.             (foreach x1 tmp
  41.                 (foreach x2 (vl-remove x1 tmp)
  42.                     (if (apply '_inside-p (append (cdr x2) (cdr x1)))
  43.                         (setq sub (cons (car x2) sub))
  44.                     )
  45.                 )
  46.                 (setq ref (cons (cons (car x1) sub) ref)
  47.                       sub nil
  48.                 )
  49.             )
  50.             (_process (_sort lst ref) ref)
  51.         )
  52.     )
  53. )
I have also used Entity Handles over Entity Names as its easier to track.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #9 on: May 14, 2013, 09:30:26 AM »
Yes, it works perfectly!  :-)
« Reply #10 on: May 14, 2013, 09:58:38 AM »
Here are my suggestions for your function:
  1. (defun eea-test-1-lm ( / f e i l s )
  2.
  3.     (defun f ( l a / b c )
  4.         (foreach x l
  5.             (if (vl-every '<= (car a) (car x) (cadr a))
  6.                 (setq b (cons x b))
  7.                 (setq c (cons x c))
  8.             )
  9.         )
  10.         (cons
  11.             (if b
  12.                 (cons (last a) (f (cdr (reverse b)) (last b)))
  13.                 (cddr a)
  14.             )
  15.             (if c
  16.                 (f (cdr (reverse c)) (last c))
  17.             )
  18.         )
  19.     )
  20.
  21.     (if (setq s (ssget '((0 . "LWPOLYLINE") (90 . 4) (-4 . "&=") (70 . 1))))
  22.         (progn
  23.             (repeat (setq i (sslength s))
  24.                 (setq e (ssname s (setq i (1- i)))
  25.                       l (cons (reverse (cons (cdr (assoc 5 (entget e))) (reverse (acet-geom-extents e)))) l)
  26.                 )
  27.             )
  28.             (setq l (vl-sort l (function (lambda ( a b ) (< (caar a) (caar b))))))
  29.             (f (cdr l) (car l))
  30.         )
  31.     )
  32. )
I hope you don't mind  :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #11 on: May 14, 2013, 10:02:08 AM »
the other - whiling away the way:
  3.     (cond ((not l)
  4.            (cons (if b
  6.                    (cddr a)
  7.                  )
  8.                  (if c
  10.                  )
  11.            )
  12.           )
  15.     )
  16.   )
  18.     (progn (setq l (vl-sort (mapcar (function (lambda (a) (reverse (cons a (acet-geom-extents a))))) (acet-ss-to-list l))
  19.                             (function (lambda (a b) (<= (caar a) (caar b))))
  20.                    )
  21.            )
  22.            (f (cdr l) (car l) nil nil)
  23.     )
  24.   )
  25. )
maybe it's slower but shorter... ;)
« Reply #12 on: May 14, 2013, 10:11:22 AM »
Evgeniy,
When using:
This will never be true:
  1. (vl-every (function <=) (car a) (caar l) (cadr a))
Since the coordinates of (car a) [upper-right corner] will always be greater than (cadr a) [lower-left corner]
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #13 on: May 14, 2013, 10:21:52 AM »
Thank you!  Fixed...  :-)
  1. (defun eea-test-2 (/ f l)
  3.     (cond ((not l)
  4.            (cons (if b
  6.                    (cddr a)
  7.                  )
  8.                  (if c
  10.                  )
  11.            )
  12.           )
  13.           ((vl-every (function >=) (car a) (caar l) (cadr a)) (f (cdr l) a (cons (car l) b) c))
  15.     )
  16.   )
  19.                             (function (lambda (a b) (>= (caar a) (caar b))))
  20.                    )
  21.            )
  23.     )
  24.   )
  25. )
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #14 on: May 14, 2013, 10:37:02 AM »
new version:
  1. (defun eea-test-3 (/ f l)
  3.     (cond ((not l)
  4.            (cons (if b
  5.                    (cons a (f (cdr (reverse b)) (last b) nil nil))
  6.                    (list a)
  7.                  )
  8.                  (if c
  10.                  )
  11.            )
  12.           )
  13.           ((equal (acet-geom-extents a) (ACET-GEOM-SS-EXTENTS-ACCURATE (ssadd (car l) (ssadd a (ssadd)))))
  14.            (f (cdr l) a (cons (car l) b) c)
  15.           )
  17.     )
  18.   )
  20.     (progn (setq l (vl-sort (acet-ss-to-list l)
  21.                             (function (lambda (a b) (>= (vlax-curve-getarea a) (vlax-curve-getarea b))))
  22.                    )
  23.            )
  25.     )
  26.   )
  27. )
running slow...  :-D
