Author Topic: vl-cmdf or command?  (Read 2760 times)
masao
vl-cmdf or command?
« on: July 16, 2023, 01:13:32 AM »
if i write a lisp use command,than i change to vl-cmdf now.
else code is same
just command work and vl-cmdf work?have any different?
but everyone usually use command.
ex.
defun c:xx
setq .......
setq .......
(command "")
and
defun c:xx
setq .......
setq .......
(vl-cmdf "")
« Last Edit: July 16, 2023, 07:47:03 AM by masao »
ribarm
  • Marko Ribar, architect
Re: vl-cmdf or command?
« Reply #1 on: July 16, 2023, 08:18:11 AM »
I usualy use (vl-cmdf) instead of (command) as it's slightly faster and speed is even better than (command-s)... I usualy don't have exactly the need to return T after execution of commands, so IMHO (vl-cmdf) useage is appropriate and justified... Just always watch that somewhere you don't make logical construction forgrtting that (vl-cmdf) returns T after execution, so if not predicted this way command main routine may fail...
M.R. on Youtube
masao
« Reply #2 on: July 16, 2023, 09:52:24 AM »
sorry,what means "returns T after execution"?
because i want  to convert command into vl-cmdf but my code usually end place use command.
because my code is easy so can not know both of different.
thanks so much.
« Last Edit: July 16, 2023, 10:13:22 AM by masao »
ribarm
« Reply #3 on: July 16, 2023, 10:57:43 AM »
(vl-cmdf) returns T after execution, so logic of (if) statements, or (cond), or (and), or (or), or (not) must be adequate and in relation that routine continues to execute till the end and that logic is correctly implemented in the code...
M.R. on Youtube
masao
« Reply #4 on: July 16, 2023, 11:14:55 AM »
thanks so much. but use (if) or (while) or (or) or (cond) not end in command code is can not work,so if my code can work ,convert command into vl-cmdf,it is ok.
ribarm
« Reply #5 on: July 16, 2023, 11:22:29 AM »
Look if your routine works with (command) correctly, and you had it placed where logic of statements influence to correct evaluation of that specific paragraph, it is not advisable to change (command) to (vl-cmdf) though you could always imitate nil as a return : (not (vl-cmdf tokens)) = (command tokens)... So if you have separate statements where it's not neccessary to distinguish returns of statements, you are ok with changing (command) => (vl-cmdf)...
M.R. on Youtube
ribarm
« Reply #6 on: July 16, 2023, 11:38:32 AM »
For more info what command function is adequate for usage, I strongly suggest that you analyze *.lsp template for coding placed here :
https://www.theswamp.org/index.php?topic=57865.msg611757#msg611757
In this reply it was adopted usage of syntax : (exe (list tokens)) instead of all 3 : (command), (vl-cmdf) and (command-s)... There are no speed interuptions, it's just that with (exe (list tokens)) you must write like as you are using (command-s) tokens - it's not advisable to interupt with this construction :
(exe (list "_.PLINE"))
(foreach p plst
  (exe (list "_non" p))
(exe (list "_C"))
So it must look like this :
(exe (cons "_.PLINE" (apply (function append) (append (mapcar (function (lambda ( p ) (list "_non" p)) plst) (list (list "_C"))))))
« Last Edit: July 16, 2023, 11:42:54 AM by ribarm »
M.R. on Youtube
masao
« Reply #7 on: July 16, 2023, 11:57:16 AM »
(foreach p plst
(exe (list "_C"))
thank you so much.
i am not understand these code yet,but thank you provide information.
i just easy code now.
like this
(defun c:ss(/ ss p1 p2)
 (setq ss (ssget))
 (setq p1 (getpoint "\nbase point:"))
 (setq p2 (polar p1 0 0))
(vl-cmdf "_scale" ss "" p1 "_reference" p1 pause)
i just convert command into vl-cmdf ,i just write easy code now. :laugh:
ribarm
« Reply #8 on: July 16, 2023, 11:59:06 AM »
One more info ab (exe (list tokens))...
It was hardcoded that it returns T upon execution, so it's very similar to (vl-cmdf), only it's little more advanced as it uses (command-s) where it's neccesity... (error handler)
M.R. on Youtube
ribarm
« Reply #9 on: July 16, 2023, 12:14:00 PM »
Here, I've made test for you do confirm what I was speaking...
  1. (defun c:tttt ( / *error* tttt wcs initvalueslst ucsf ti p lst )
  2.
  3.   (defun *error* ( m )
  4.     (if wcs
  5.       (if ucsf
  6.         (while
  7.           (not
  8.             (and
  9.               (equal (getvar (quote ucsxdir)) (car ucsf) 1e-6)
  10.               (equal (getvar (quote ucsydir)) (cadr ucsf) 1e-6)
  11.               (equal (trans (list 0.0 0.0 1.0) 1 0 t) (caddr ucsf) 1e-6)
  12.             )
  13.           )
  14.           (exe (list "_.UCS" "_P"))
  15.         )
  16.       )
  17.     )
  18.     (while (= 8 (logand 8 (getvar (quote undoctl))))
  19.       (if (not (exe (list "_.UNDO" "_E")))
  20.         (if doc
  21.           (vla-endundomark doc)
  22.         )
  23.       )
  24.     )
  25.     (if initvalueslst
  26.       (mapcar (function apply_cadr->car) initvalueslst)
  27.     )
  28.     (foreach fun (list (quote tttt) (quote vl-load) (quote exe) (quote cmdfun) (quote cmderr) (quote catch_cont) (quote apply_cadr->car) (quote ftoa))
  29.       (setq fun nil)
  30.     )
  31.     (if doc
  32.       (vla-regen doc acactiveviewport)
  33.     )
  34.     (if m
  35.       (prompt m)
  36.     )
  37.     (princ)
  38.   )
  39.
  40.   (defun tttt ( wcs / sysvarpreset sysvarlst sysvarvals ) ;;; wcs (T/nil) ;;; cad, doc, alo, spc - global variables (Visual Lisp main VLA-OBJECT pointers) ;;; vl-load exe cmdfun cmderr catch_cont apply_cadr->car ftoa - library sub functions common for standard template initialization ;;;
  41.
  42.     (defun vl-load nil
  43.       (or cad
  44.           (setq cad (vlax-get-acad-object))
  45.           (progn
  46.             (vl-load-com)
  47.             (setq cad (vlax-get-acad-object))
  48.           )
  49.         )
  50.       )
  51.       (or doc (setq doc (vla-get-activedocument cad)))
  52.       (or alo (setq alo (vla-get-activelayout doc)))
  53.       (or spc (setq spc (vla-get-block alo)))
  54.     )
  55.
  56.     ;;; sometimes not needed to use/initialize AxiveX Visual Lisp extensions - (comment/uncomment) following line ;;;
  57.     (or (and cad doc alo spc) (vl-load))
  58.
  59.     (defun exe ( tokenslist )
  60.       ( (lambda ( tokenslist / ctch )
  61.           (if (vl-catch-all-error-p (setq ctch (cmdfun tokenslist t)))
  62.             (progn
  63.               (cmderr tokenslist)
  64.               (catch_cont ctch)
  65.             )
  66.             (progn
  67.               (while (< 0 (getvar (quote cmdactive)))
  68.                 (vl-cmdf "")
  69.               )
  70.               t
  71.             )
  72.           )
  73.         )
  74.         tokenslist
  75.       )
  76.     )
  77.
  78.     (defun cmdfun ( tokenslist flag / ctch ) ;;; tokenslist - command parameters list of strings ;;; flag - if "t" specified, upon successful execution returns t, otherwise if "nil" specified, return is always nil no matter what outcome of function execution is - it should be successful anyway if specified tokenslist was hardcoded correctly... ;;;
  79.       (if command-s
  80.         (if flag
  81.           (if (not (vl-catch-all-error-p (setq ctch (vl-catch-all-apply (function command-s) tokenslist))))
  82.             flag
  83.             ctch
  84.           )
  85.           (if (vl-catch-all-error-p (setq ctch (vl-catch-all-apply (function command-s) tokenslist)))
  86.             ctch
  87.           )
  88.         )
  89.         (if flag
  90.           (if (not (vl-catch-all-error-p (setq ctch (vl-catch-all-apply (function vl-cmdf) tokenslist))))
  91.             flag
  92.             ctch
  93.           )
  94.           (if (vl-catch-all-error-p (setq ctch (vl-catch-all-apply (function command) tokenslist)))
  95.             ctch
  96.           )
  97.         )
  98.       )
  99.     )
  100.
  101.     (defun cmderr ( tokenslist ) ;;; tokenslist - list of tokens representing command syntax at which used (cmdfun) failed with successful execution ;;;
  102.       (prompt (strcat "\ncommand execution failure... error at used command tokenslist : " (vl-prin1-to-string tokenslist)))
  103.     )
  104.
  105.     (defun catch_cont ( ctch / gr )
  106.       (prompt "\nleft mouse click to continue or enter to generate catch error - ESC to break...")
  107.       (while
  108.         (and
  109.           (vl-catch-all-error-p (or ctch (setq ctch (vl-catch-all-apply (function /) (list 1 0)))))
  110.           (setq gr (grread))
  111.           (/= (car gr) 3)
  112.           (not (equal gr (list 2 13)))
  113.         )
  114.       )
  115.       (if (vl-catch-all-error-p ctch)
  116.         ctch
  117.       )
  118.     )
  119.
  120.     (defun apply_cadr->car ( sysvarvaluepair / ctch )
  121.       (setq ctch (vl-catch-all-apply (function setvar) sysvarvaluepair))
  122.       (if (vl-catch-all-error-p ctch)
  123.         (progn
  124.           (prompt (strcat "\ncatched error on setting system variable : " (vl-prin1-to-string (vl-symbol-name (car sysvarvaluepair))) " with value : " (vl-prin1-to-string (cadr sysvarvaluepair))))
  125.           (catch_cont ctch)
  126.         )
  127.       )
  128.     )
  129.
  130.     (defun ftoa ( n / m a s b )
  131.       (if (numberp n)
  132.         (progn
  133.           (setq m (fix ((if (< n 0) - +) n 1e-8)))
  134.           (setq a (abs (- n m)))
  135.           (setq m (itoa m))
  136.           (setq s "")
  137.           (while (and (not (equal a 0.0 1e-6)) (setq b (fix (* a 10.0))))
  138.             (setq s (strcat s (itoa b)))
  139.             (setq a (- (* a 10.0) b))
  140.           )
  141.           (if (= (type n) (quote int))
  142.             m
  143.             (if (= s "")
  144.               m
  145.               (if (and (= m "0") (< n 0))
  146.                 (strcat "-" m "." s)
  147.                 (strcat m "." s)
  148.               )
  149.             )
  150.           )
  151.         )
  152.       )
  153.     )
  154.
  155.     (setq sysvarpreset
  156.       (list
  157.         (list (quote cmdecho) 0)
  158.         (list (quote 3dosmode) 0)
  159.         (list (quote osmode) 0)
  160.         (list (quote unitmode) 0)
  161.         (list (quote cmddia) 0)
  162.         (list (quote ucsvp) 0)
  163.         (list (quote ucsortho) 0)
  164.         (list (quote projmode) 0)
  165.         (list (quote orbitautotarget) 0)
  166.         (list (quote insunits) 0)
  167.         (list (quote hpseparate) 0)
  168.         (list (quote hpgaptol) 0)
  169.         (list (quote halogap) 0)
  170.         (list (quote edgemode) 0)
  171.         (list (quote pickdrag) 0)
  172.         (list (quote qtextmode) 0)
  173.         (list (quote dragsnap) 0)
  174.         (list (quote angdir) 0)
  175.         (list (quote aunits) 0)
  176.         (list (quote limcheck) 0)
  177.         (list (quote gridmode) 0)
  178.         (list (quote nomutt) 0)
  179.         (list (quote apbox) 0)
  180.         (list (quote attdia) 0)
  181.         (list (quote blipmode) 0)
  182.         (list (quote copymode) 0)
  183.         (list (quote circlerad) 0.0)
  184.         (list (quote filletrad) 0.0)
  185.         (list (quote filedia) 1)
  186.         (list (quote autosnap) 1)
  187.         (list (quote objectisolationmode) 1)
  188.         (list (quote highlight) 1)
  189.         (list (quote lispinit) 1)
  190.         (list (quote layerpmode) 1)
  191.         (list (quote fillmode) 1)
  192.         (list (quote dragmodeinterrupt) 1)
  193.         (list (quote dispsilh) 1)
  194.         (list (quote fielddisplay) 1)
  195.         (list (quote deletetool) 1)
  196.         (list (quote delobj) 1)
  197.         (list (quote dblclkedit) 1)
  198.         (list (quote attreq) 1)
  199.         (list (quote explmode) 1)
  200.         (list (quote frameselection) 1)
  201.         (list (quote ltgapselection) 1)
  202.         (list (quote pickfirst) 1)
  203.         (list (quote plinegen) 1)
  204.         (list (quote plinetype) 1)
  205.         (list (quote peditaccept) 1)
  206.         (list (quote solidcheck) 1)
  207.         (list (quote visretain) 1)
  208.         (list (quote regenmode) 1)
  209.         (list (quote celtscale) 1.0)
  210.         (list (quote ltscale) 1.0)
  211.         (list (quote osnapcoord) 2)
  212.         (list (quote grips) 2)
  213.         (list (quote dragmode) 2)
  214.         (list (quote lunits) 2)
  215.         (list (quote pickstyle) 3)
  216.         (list (quote navvcubedisplay) 3)
  217.         (list (quote pickauto) 3)
  218.         (list (quote draworderctl) 3)
  219.         (list (quote expert) 5)
  220.         (list (quote auprec) 6)
  221.         (list (quote luprec) 6)
  222.         (list (quote pickbox) 6)
  223.         (list (quote aperture) 6)
  224.         (list (quote osoptions) 7)
  225.         (list (quote dimzin) 8)
  226.         (list (quote pdmode) 35)
  227.         (list (quote pdsize) -1.5)
  228.         (list (quote celweight) -1)
  229.         (list (quote cecolor) "BYLAYER")
  230.         (list (quote celtype) "ByLayer")
  231.         (list (quote clayer) "0")
  232.       )
  233.     )
  234.     (setq sysvarlst (mapcar (function car) sysvarpreset))
  235.     (setq sysvarvals (mapcar (function cadr) sysvarpreset))
  236.     (setq sysvarvals
  237.       (vl-remove nil
  238.         (mapcar
  239.           (function (lambda ( x )
  240.             (if (getvar x) (nth (vl-position x sysvarlst) sysvarvals))
  241.           ))
  242.           sysvarlst
  243.         )
  244.       )
  245.     )
  246.     (setq sysvarlst
  247.       (vl-remove-if-not
  248.         (function (lambda ( x )
  249.           (getvar x)
  250.         ))
  251.         sysvarlst
  252.       )
  253.     )
  254.     (setq initvalueslst
  255.       (apply (function mapcar)
  256.         (cons (function list)
  257.           (list
  258.             sysvarlst
  259.             (mapcar (function getvar) sysvarlst)
  260.           )
  261.         )
  262.       )
  263.     )
  264.       (cons (function setvar)
  265.         (list
  266.           sysvarlst
  267.           sysvarvals
  268.         )
  269.       )
  270.     )
  271.     (while (= 8 (logand 8 (getvar (quote undoctl))))
  272.       (if (not (exe (list "_.UNDO" "_E")))
  273.         (if doc
  274.           (vla-endundomark doc)
  275.         )
  276.       )
  277.     )
  278.     (if (not (exe (list "_.UNDO" "_M")))
  279.       (if doc
  280.         (vla-startundomark doc)
  281.       )
  282.     )
  283.     (if wcs
  284.       (if (= 0 (getvar (quote worlducs)))
  285.         (progn
  286.           (setq ucsf
  287.             (list
  288.               (getvar (quote ucsxdir))
  289.               (getvar (quote ucsydir))
  290.               (trans (list 0.0 0.0 1.0) 1 0 t)
  291.             )
  292.           )
  293.           (exe (list "_.UCS" "_W"))
  294.         )
  295.       )
  296.     )
  297.     wcs
  298.   )
  299.
  300.   (setq wcs (tttt t)) ;;; starting "library" template sub function - initialization ;;;
  301.   (setq ti (car (_vl-times)))
  302.   (while (setq p (getpoint (if lst (car lst) "\nPick point - ENTER TO FINISH : ") "\nPick point - ENTER TO FINISH : "))
  303.     (setq lst (cons p lst))
  304.   )
  305.   ;|
  306.   (exe (list "_.PLINE"))
  307.   (foreach p lst
  308.     (exe (list "_non" p))
  309.   )
  310.   (exe (list "_C"))
  311.   |;
  312.   (if (exe (cons "_.PLINE" (apply (function append) (append (mapcar (function (lambda ( x ) (list "_non" x))) lst) (list (list "_C"))))))
  313.     (prompt "\n(exe) returned T")
  314.     (prompt "\n(exe) returned nil")
  315.   )
  316.   (prompt "\nElapsed time : ") (prompt (ftoa (- (car (_vl-times)) ti))) (prompt " milliseconds...")
  317.   (prompt "\nFor UNDO - type \"UNDO\" - \"Back\" option...")
  318.   (*error* nil)
  319. )
  320.
HTH., M.R.
M.R. on Youtube
masao
« Reply #10 on: July 16, 2023, 01:00:07 PM »
i change command to vl-cmdf,but cant use esc exit lisp
if pause change getpoint use esc exit lisp,but i want see  graphics.
(defun c:past_cen(/ ss osm past_mono_base)
(setq e_lst (mapcar (function (lambda (n) (list 'setvar n (getvar n)))) '("cmdecho" "osmode")))
(defun *error* (msg)
(command-s "_.undo" "_end")
(mapcar 'eval e_lst)
(princ "")
(setq osm (getvar "osmode"))
(setvar "cmdecho" 0)
(princ "\nselect:")
(setq ss (ssget))
        (vl-cmdf "_.undo" "_begin")
(setvar "osmode" 37)
(setq past_mono_base (getpoint "\n basepoint: "))
(vl-cmdf "._COPYBASE" past_mono_base ss "")
        (while t
        (setvar "osmode" 4)
(vl-cmdf "._pasteclip" "_cen" pause)
        (vl-cmdf "_.undo" "_end")
);while
VovKa
  • Ukraine
« Reply #11 on: July 16, 2023, 03:22:28 PM »
yes, they are different
compare
(command "_line" "0,0" pause (getpoint "\npick third point: ") "")
with
(vl-cmdf "_line" "0,0" pause (getpoint "\npick third point: ") "")
Marc'Antonio Alessi
  • Marco
« Reply #12 on: July 17, 2023, 04:53:56 AM »
From help: vl-cmdf (AutoLISP)
Executes an AutoCAD command
Supported Platforms: Windows and Mac OS
Signature(vl-cmdf [arguments ...])
argumentsType: Integer, Real, String, List, or Ename (entity name)
AutoCAD commands and their options.
The arguments to the vl-cmdf function can be strings, reals, integers, or points, as expected by the prompt sequence of the executed command. A null string ("") is equivalent to pressing Enter on the keyboard. Invoking vl-cmdf with no argument is equivalent to pressing Esc and cancels most AutoCAD commands.
Return ValuesType: T
Always returns T.
RemarksThe vl-cmdf function is similar to the command function, but differs from command in the way it evaluates the arguments passed to it. The vl-cmdf function evaluates all the supplied arguments before executing the AutoCAD command, and will not execute the AutoCAD command if it detects an error during argument evaluation. In contrast, the command function passes each argument in turn to AutoCAD, so the command may be partially executed before an error is detected.
If your command call includes a call to another function, vl-cmdf executes the call before it executes your command, while command executes the call after it begins executing your command.
Some AutoCAD commands may work correctly when invoked through vl-cmdf, while failing when invoked through command. The vl-cmdf function mainly overcomes the limitation of not being able to use getXXX functions inside command.
Note: If you issue vl-cmdf from Visual LISP in AutoCAD on Windows, focus does not change to the AutoCAD window. If the command requires user input, you will see the return value (T) in the Console window, but AutoCAD will be waiting for input. You must manually activate the AutoCAD window and respond to the prompts. Until you do so, any subsequent commands will fail.
ExamplesThe differences between command and vl-cmdf are easier to see if you enter the following calls at the AutoCAD Command prompt:
Command: (command "._line" (getpoint "point?") '(0 0) "")line Specify first point: point?Specify next point or [Undo]:Command: nil
Using command, the LINE command executes first; then the getpoint function is called.
Command: (vl-cmdf "._line" (getpoint "point?") '(0 0) "")point?line Specify first point:Specify next point or [Undo]:Command: T
Using vl-cmdf, the getpoint function is called first (notice the “point?” prompt from getpoint); then the LINE command executes.
The following examples show the same commands, but pass an invalid point list argument to the LINE command. Notice how the results differ:
Command: (command "._line" (getpoint "point?") '(0) "")line Specify first point: point?Specify next point or [Undo]:Command: ERASE nilSelect objects: Specify opposite corner: *Cancel*0 found
The command function passes each argument in turn to AutoCAD, without evaluating the argument, so the invalid point list is undetected.
Command: (vl-cmdf "._line" (getpoint "point?") '(0) "")point?Application ERROR: Invalid entity/point list.nil
Because vl-cmdf evaluates each argument before passing the command to AutoCAD, the invalid point list is detected and the command is not executed.
ribarm
« Reply #13 on: July 17, 2023, 08:01:05 AM »
@masao,
I've already told you once before...
This line :
does nothing when executed...
M.R. on Youtube
masao
« Reply #14 on: July 17, 2023, 08:42:36 AM »
@masao,
This line :
if i use ESC exit lisp,how to recovery osmode and else system variable? i usually use this and it can recovery.
« Last Edit: July 17, 2023, 09:01:04 AM by masao »
