Author Topic: Why wont this routine return a value?  (Read 2091 times)
jbuzbee
« on: April 08, 2014, 09:41:18 AM »
The following should return a value if the OpenDCL form isn't opened, but it doesn't.  What am I doing wrong?
Thank you
(defun kb:TextWidthValue  (/ rValue nValue ret)
  (cond ((dcl_Form_IsActive Annotation_Palette)
(Setq rValue (dcl_ComboBox_GetTBText Annotation_Palette_TextWidth)))
(Setq rValue (dcl_ComboBox_GetTBText Annotation_Palette_TextWidth))))
  (cond ((= (strcase rValue) "NARROW") (setq nValue 1.25))
((= (strcase rValue) "STANDARD") (setq nValue 2.5))
((= (strcase rValue) "EXTENDED") (setq nValue 3.75))
(t (setq nValue 4.0)))
  (setq ret (* nValue (kb:cannoscale)))
  ret)
James Buzbee
Windows 8
irneb
Re: Why wont this routine return a value?
« Reply #1 on: April 08, 2014, 10:45:46 AM »
It's a bit impossible to test without the rest of the code. But it seems as if it should at least return 4.0 x the CAnnoScale.
That is if there's no error in one of the routines called from that function. Note an error simply stops all Lisp. It should then list an error message onto the command line. Could you please copy that into a post?
roy_043
  • BricsCAD 18
« Reply #2 on: April 08, 2014, 10:51:51 AM »
Note: your first (cond) has the same condition twice. Maybe that is causing your confusion. Although the function (if called) should still return a value.
« Reply #3 on: April 08, 2014, 02:39:19 PM »
In the first two conditions, you define a variable rvalue.
In the remaining conditions and final expression, you define & reference the variable nvalue
Note that the final variable ret is not required.
EDIT: Oops! I see I have misread the code in my haste to spot the issue... :oops:
« Last Edit: April 08, 2014, 06:38:22 PM by Lee Mac »
« Reply #4 on: April 08, 2014, 05:15:57 PM »
James,
By my reading, the code as posted should return (* 4.0 (kb:cannoscale)) or error if kb:cannoscale has a value of nil.
The last line could be simply
  1. (* nValue (kb:cannoscale))
jbuzbee
« Reply #5 on: April 09, 2014, 10:59:36 AM »
Thanks all for the insight.  I still don't know why it won't return a value when rValue is nil.  :|
James Buzbee
Windows 8
jbuzbee
« Reply #6 on: April 09, 2014, 11:27:45 AM »
Ok I re-wrote the routine based on your suggestions and still no return.  :| :|
  (setq nValue 2.5)
  (if(dcl_Form_IsActive Annotation_Palette)
;(t (setq nValue 2.5))
James Buzbee
Windows 8
jbuzbee
« Reply #7 on: April 09, 2014, 11:33:01 AM »
This works:
         (setq rValue "standard")
Thanks again!!
James Buzbee
Windows 8
irneb
« Reply #8 on: April 09, 2014, 02:39:13 PM »
    OK, going over the code again ... it would have been simple if you listed the error code as I asked in my 1st post on this thread:
    You'll note that your code isn't initializing the rValue variable in all cases. So if the dialog isn't visible then rValue = nil. Then the 1st test in the cond is using the strcase function. This will error if the argument contains anything but a string. So it errors because the value inside rValue is nil and not a string. Therefore once it reaches the first strcase call, the entire defun errors out - with something like:
    bad argument type: stringp nil
    There are various ways you could go about fixing it:
    • Initialize rValue to the empty string "" (or any string whatsoever except one of the 3 options) at the same place you're initializing nValue (i.e. before the if, though anywhere in the defun's root scope before the cond would also suffice)
    • Set rValue in the else portion if the if (again empty or anything but the options). Similar to your last post
    • Add a condition in the cond before any of the strcase's which tests if the value inside rValue is a string. E.g. using (= (type rValue) 'STR); OR
    • Add a condition in the cond before any of the strcase's which tests if the value inside rValue not nil. E.g. using (not (null rValue))
    There might be other solutions also, but these are some I thought of.[/list]
    « Last Edit: April 09, 2014, 02:42:22 PM by irneb »
